Stepper wiring mismatch?
Posted: Thu May 16, 2019 7:20 pm
I've got OEM steppers from a V3 kit, and one new one attached to an extruder.
1) want to control them all properly via DUET WiFi board.
2) need to attach a connector to the wires on the new one; wire colors don't match
SO, I opened them up to compare wiring + main gear.
They look the same, just slightly different gear styles, and wire colors:
OEM extruder
LDM 1
LDM 2
They both have 50 teeth and 6 contact points per pole.
Can I safely assume that IF they are both 1.8° steppers,
AND,
IF I do this connector/wiring match:
G BL R Y OEM
G BL BK R LDM extruder
THEN I'm doing it correctly and not _likely_ to fry stuff?
Any feedback appreciated!!
OEM extruder
LDM 1
LDM 2
AND,
G BL R Y OEM
