My Quadcopter Build
Posted: Sat Aug 29, 2015 6:47 am
by Khalid Khattak
I am currently making my Quadcopter using 19.05mm square Aluminum tubing as frame. I shall post my progress as it goes on. I am new to this hobby. Today i designed Motor mount that will be installed on Aluminum Arms. I am printing this motor mount in Horizontal position. Also the link of thingiverse:
http://www.thingiverse.com/thing:989625" onclick="window.open(this.href);return false;
Re: My H-Frame Quadcopter Build
Posted: Sun Aug 30, 2015 12:41 am
Looks great so far!
After building my own, I think that the best wisdom that I can share is:
make it rigid
make it light
plan how much it will weigh instead of finding out later
and make sure that you order the right motor/prop combo for that weight
Good luck, keep us posted on your progress!
edit: keep wire management in mind too.
Posted: Sun Aug 30, 2015 4:57 am
by Khalid Khattak
Thanks for suggestion i will look how to optimize the design. Already orders all the electronics stuff and received them. Following are the links where i get all my stuff at good bargain price. I will keep sharing the links.
FPV: US82$
6km FPV Combo System Boscam 5.8Ghz 600mw Video Transmitter and Receiver Suit For SJ4000 XiaoMi Yi Sport Action Camera Gopro 3 4
http://www.aliexpress.com/item/6km-FPV- ... 39335.html" onclick="window.open(this.href);return false;
Battery Charging Stuff:
Original SKYRC Imax B6 60W Mini Professional Balance Charger Discharger For RC Helicopter Toys Quadcopter Battery Charging ( US $37.85 )
http://www.aliexpress.com/item/Original ... 80024.html" onclick="window.open(this.href);return false;
Newest Parallel Charging Board Balance charge up to 6 packs 2-6s Lipo Battery for iMAX B6 B6AC B8 Charger rc helicopter part ( US $4.69 )
http://www.aliexpress.com/item/wholesal ... 13061.html" onclick="window.open(this.href);return false;
12V 5A AC/DC Power adaptor for Imax B5 B6 Balancer Charger Power Supply Adaptor rc helicopter quadcopter Battery Balance Charger( US $3.30 )
http://www.aliexpress.com/item/12V-5A-A ... 07640.html" onclick="window.open(this.href);return false;
Battery Lipo: ( US $15.69 )
11.1V 2200mAh 3S 30C Li-Po Li-on Battery T Plug Dean for RC Quadcopter Motor Car Boat
http://www.aliexpress.com/item/11-1V-22 ... 01311.html" onclick="window.open(this.href);return false;
Brushless Motors with impellers and ESC:
Freeship 4set/lot EMAX 2212 MT2213 935KV Brushless Motor for DJI F450 F550 X525 Multicopter Quadcopter 1045 Propellers Wholesale( US $50.81 )
http://www.aliexpress.com/item/Freeship ... 94669.html" onclick="window.open(this.href);return false;
free shipping!! Wholesale Hobbywing FlyFun 30A ESC 2-6S Speed Control for Airplane/Helicopter FlyFun-40 OPTO( US $15.91 x 4 )
http://www.aliexpress.com/item/free-shi ... 33876.html" onclick="window.open(this.href);return false;
Ardupilot and Telemetry: ( US $73.88 )
APM2.6 ArduPilot UAV Flight Controller APM 2.6+ 6M GPS w/ Compass+Power Module+ 915Mhz 3DR Radio Telemetry
http://www.aliexpress.com/item/APM2-6-A ... 29227.html" onclick="window.open(this.href);return false;
Gimbal: ( US $41.59 )
RTF Brushless Gimbal Camera w/ 2208 Motors BGC Controller Board CNC ALU Metal For SJ4000 Black
http://www.aliexpress.com/item/RTF-Brus ... 47120.html" onclick="window.open(this.href);return false;
Transmitter/Receiver:( US $86.01 )
Flysky FS-TH9X 2.4G 9CH Radio RC Control Transmitter FS-R9B Receiver for RC Quad
http://www.aliexpress.com/item/Flysky-F ... 67391.html" onclick="window.open(this.href);return false;
Meanwhile my 3D model is for your review.
Posted: Sun Aug 30, 2015 5:18 am
by Khalid Khattak
Its not going to be H-Frame
Posted: Sun Aug 30, 2015 11:28 am
by Khalid Khattak
The body took four hours.
Posted: Sun Aug 30, 2015 2:07 pm
by nitewatchman
Cool!
Posted: Sat Sep 05, 2015 11:03 am
by Khalid Khattak
After lot of design iterations i came up with this fantastic design. 1- The arms of this quadcopter can be set at any angle. Even you can fold it.
2- The body can be extended or reduced.
3- This can turn into Square and H configuration.
4- The Aluminum machining was done on CNC and the motor mounts were 3D printed.
Now I have to make the body of this quadcopter i.e. the center piece that will act as a bridge between the arms.
So far the weight of Quadcopter as shown in following picture came out around 600gm.
he centre Aluminum square piece is just kept to hold the forearm and back. Its not the part of Qadcopter. 930KV motors with 10inch propeller
Posted: Sat Sep 05, 2015 3:17 pm
by Khalid Khattak
The design...
Posted: Sat Sep 05, 2015 5:44 pm
Awesome!
Posted: Fri Sep 11, 2015 12:52 pm
by Khalid Khattak
some more 3d modelling work i did recently.
Posted: Sat Sep 12, 2015 6:27 am
by Khalid Khattak
The first part i printed today..
Posted: Sat Sep 12, 2015 10:51 am
by Khalid Khattak
Rear Part
Posted: Sun Sep 13, 2015 4:33 am
by Khalid Khattak
Finally.. Found some improvement during assembling. Once electronics complete i will revise the 3D model and post in thingiverse.
Re: My Quadcopter Build
Posted: Mon Sep 14, 2015 1:35 pm
by Khalid Khattak
Shortened the arms. The landing gear are crude, the printing will be soon done. However i will use the Carbon Fiber rods for landing gear as shown in picture.... Now its look good to me
Posted: Mon Sep 14, 2015 5:37 pm
Looking very, very nice!
Posted: Sat Sep 19, 2015 6:01 am
by Khalid Khattak
Still Work in Progress for the quadcopter. Modified the body a little bit. Here is the snapshot of Lipo Battery Holder (Lipo battery 14.8V 5000mah) Dimensions of the battery is: 136mm x 44mm x 39mm (LWH). The printing in progress.
Posted: Sat Sep 19, 2015 9:18 am
by barry99705
Man, I miss my quad.
Posted: Sat Sep 19, 2015 12:49 pm
by Khalid Khattak
Barry, what happen to your quad?
Here is the latest updates...
Posted: Sat Sep 19, 2015 7:57 pm
by barry99705
It tried to drill for oil. Was a kickstarter quad that the developer ran right after shipping all the quads. The brains never did work quite right, even after a couple firmware upgrades.
[img]
https://lh3.googleusercontent.com/-NIVp ... 170347.jpg[/img]
The wires that hook to nothing on the right of the frame used to connect to the radio, it went for it's own flight after the quad did an uncommanded barrel roll while hovering. Radio came loose and hit a prop I think, never did find it.
Hopefully the next kickstarter I supported works out better. I do know there has been much more developer communication with this one.
http://www.ascentaerosystems.com/sprite" onclick="window.open(this.href);return false;
Posted: Thu Sep 24, 2015 2:57 am
by Khalid Khattak
Barry that was quite unfortunate for you
Got some time to design and print the landing gears. The plastic parts can take load upto 2Kg and shock load upto 5Kg.
Posted: Thu Sep 24, 2015 7:34 am
by Khalid Khattak
Some updates
Posted: Thu Sep 24, 2015 8:01 am
What are the teardrop shaped extrusions for? Just "bumpers" or caps for the landing skids?
Posted: Thu Sep 24, 2015 8:14 am
by Khalid Khattak
Bumpers, Caps yes, but, i designed them to keep the whole thing levelled. Otherwise it may have a chance to tip-over...
Posted: Thu Sep 24, 2015 3:22 pm
Moved to the General FPV topics at your request. I left a shadow in the What are YOU making topic.
Posted: Sat Sep 26, 2015 12:59 am
by Khalid Khattak
Thanks, now its in right spot
