Female pin connectors
A place for the physical connections
cpunches
Post by cpunches »
Can anyone give me the specs on the connector pins that come in the Rambo kit? I managed to use all of them up during my build and I still have a couple of connections that I'd like to redo. I ordered some from Jameco but they were the wrong size and won't fit the 4-pin connectors that plug into the Rambo.
Re: Female pin connectors
I bought some from Ultimachine for the same reason. They came in a Farnell bag with the numbers on it, so I'll check it tonight and post it for you.
http://www.mouser.com/ProductDetail/Mol ... Dr7T8xxg== Housings
http://www.mouser.com/ProductDetail/Mol ... uX%2foQ%3d Pins
http://www.mouser.com/Molex/Headers-Wir ... loZ1yzvh3j Everything
The above links are for the housings and pins you need.
The last link is in case you want to see the whole series.
cpunches
Post by cpunches »
Thank you both.
Return to “Nuts and Bolts”
