I saw a enclosure for the 7" screen that fit in the Rostock Max V2 original LCD bay. It was also tilted. Anyone remember that one? I'm looking to print it.
Thanks
Enclosure for 7" Panel Due
Re: Enclosure for 7" Panel Due
DC42 has one. He is the Duet and Due guy, after all.
http://www.thingiverse.com/thing:656884
It suits what I have in mind as well...
Looks like it must have the pcb mounted with a extension cable or maybe it is off-center... there must be a cover that goes on the front of it?
Bob
Delta's are the way!
The mounts for the PanelDue driver and the Duet are in the "snorkel" plus there is a cover, I forgot to link itcrocky wrote:It suits what I have in mind as well...
http://forum.seemecnc.com/download/file.php?id=11747
you have version 2.4
here is a copy of version 2.6 your faceplate is version 1.5
here is version 1.8
here is version 1.8
SeeMeCNC Rostock Max V2
Makerbot Replicator Gen 5
Here is how I attached the Due and Duet using the mount.
http://forum.seemecnc.com/viewtopic.php ... 100#p85491
Thank you..... and 3D Print?Outsider wrote:you have version 2.4
PanelDue and Duet Base for ROSTOCK Max V2 - Version 2.6.stl
here is version 1.8
PanelDue and Duet Faceplate V2 Version 1.8.stl
Bob
