Duet connector part numbers
Posted: Wed Feb 03, 2016 11:58 pm
Ones anyone know what the part number for the motor connectors on the duet is?
Mine arrived from filastruder, but with no female connectors.
Re: Duet connector part numbers
Posted: Thu Feb 04, 2016 12:10 am
by IMBoring25
Think3DPrint3D apparently changed connectors part way through 0.8.5 production. If the headers are not keyed, they're 2.54 mm Dupont connectors. If they are keyed, they're .100" Molex KK-style connectors. Exact part numbers would depend on what material you want to use for the terminals and the number of pins you want (or need) to use in each housing.
Posted: Thu Feb 04, 2016 1:26 am
Thanks, they're keyed.
Of course I have literally hundreds of DuPont connectors, and no molex connectors.
Posted: Thu Feb 04, 2016 9:27 am
I'm in the same boat, Polygon.
I'll need to order the Molex KK connectors from Jameco and I'll buy some 2 pin male DuPont connectors from Hansen Hobbies in order to make all the little adapter cables I need - I've already got enough of the 4 pin male latching connectors...
Posted: Fri Feb 05, 2016 1:22 pm
I ordered what I think are compatible part numbers from Digikey, if it turns out I ordered the correct ones, I'll post the part numbers here.
Posted: Fri Feb 05, 2016 1:39 pm
This is what I ordered yesterday from Jameco:
2 Pin - 22-01-3027 (jameco p/n 234798)
3 Pin - 22-01-3037 (p/n 234801)
4 Pin - 22-01-3047 (p/n 234819)
Crimp sockets, jameco p/n 736501.
Posted: Fri Feb 05, 2016 2:56 pm
Just to be different I ordered
0022012045 -- 4 Conductor
0022012035 -- 3 Conductor
0022012025 -- 2 Conductor
0008500032 -- The pins
Which I think are the same without the locking ramp
Posted: Sat Feb 06, 2016 11:24 am
by 3D-Print
geneb wrote:This is what I ordered yesterday from Jameco:
Awesome, thanks for posting!
