What geneb said....the red text in particular is the interesting part. However, even that one line tells me it's failing at the linker stage, which means the actual compiling worked.
Anyway, I downloaded a fresh copy of seeme 0.92 from their site and compiled it. Then I enabled the servo feature and compiled again. Worked fine using the Arduino 1.6.9 IDE that I had loaded. (By worked, I mean compiled and linked without error. I didn't actually try to use the servo feature.)
So I went and got the most recent version of the IDE (1.8.0) and tried again. And I now see your error, I think. The errors of note are multiple instances of (They're red in the actual IDE, so easy to spot, but don't be afraid of copying the entire block of compile info.):
`stepperWait' referenced in section `.text' of C:\Users\Eric\AppData\Local\Temp\ccbAU07Q.ltrans13.ltrans.o: defined in discarded section `.text' of C:\Users\Eric\AppData\Local\Temp\arduino_build_644034\sketch\HAL.cpp.o (symbol from plugin)
So, my advice to you is to simply go get an older version of the IDE from the arduino site. 1.6.9 worked for me, but you could go even further back.
But if you're interested, I also know where this error is coming from. The 'stepperWait' is declared in HAL.cpp, but all the C code that used to use the variable has been replaced with assembly code blocks for efficiency's sake. The problem is that there are NO non-assembly references to the symbol left, so it got discarded as unused data. Which is fine, that's a good thing in most cases and is supposed to happen. The fact it didn't do it in older versions of the IDE isn't really a bug, although it sure feels like one to you. It worked before by luck of implementation, not because it should have. The mistake is arguably in the code...whoever converted C to assembly code should also have added an explicit directive "__attribute__((used))" to protect that variable.
But you didn't really need to know that, did you? Going back a few versions of the IDE is actually a fairly common fix for new and unexpected problems.
(edit- had typoed 1.6.9 as 1.9.6. Fixed now.)
