![Smile :)](./images/smilies/icon_e_smile.gif)
No pics yet, but here's a few things that are "for sure".
1. Power supply remains in the bottom.
2. RAMBo, LCD, and stepper motors are in the top.
3. ALL the vertical structural components are now injection molded out of glass-filled nylon (except the towers!).
4. Belt tension adjustment is done by rotating the stepper motor and not a turn-around that can tilt.
5. There's a specific location in the top to accommodate the Rasberry Pi 3. You can get one as an add-in when you order and all pre-built v3s will include it.
6. Removable connectors are back! The original Indiegogo Rostock MAX v1s included a RAMBo that had pluggable compression terminals on ALL the connector positions, not just the power connector as it is now.
7. The HE280 hot end from the Eris will be the new stock hot end for the Rostock MAX v3. The hot end design has been tweaked a bit to use heater cartridges and will include a thermal fuse as a safety measure. No more RTV on the hot end!
8. The auto-calibration system that the Eris uses will also be part of the v3.
9. No more dragging piles of wire through the towers! 1 12ga black wire in the X tower up to the RAMBo, 1 12ga red wire in the Z tower up to the RAMBo and 1 12ga black wire in the Y tower that goes down to the Onyx. The Onyx thermistor wires will also travel in the Y tower. The Onyx + connection will be straight from the power supply.
The build time is going to be very fast - you'll build the top section, then the bottom section, seat the towers, attach the carriages, mount the top and then run the belts.
More later!
