Extruder and bed wont heat up?
Posted: Mon Dec 19, 2016 7:48 pm
by TKCC71
Last night I did a print all night no problem. I shut it down this morning and turned it back on. Connected to my slicer and now nothing will heat up? Tried a different slicer and its a no go.
Temp and extruder on the LCD say
Temp
Extruder: Def
Bed:Def
Anyone have any idea whats going on why it wont turn on?
Re: Extruder and bed wont heat up?
Posted: Mon Dec 19, 2016 8:45 pm
by Noircogi
Make sure the ambient temperature is above 18C or you'll get that message.
Make sure the connector on the hot-end is well seated.
Posted: Mon Dec 19, 2016 9:03 pm
by TKCC71
Yep that was the issue. I got a heat gun and slighty warmed it up a bit. Its 22 degrees outside and the printer is in the basement. :)
THanks
Posted: Mon Dec 19, 2016 11:13 pm
by Minim
Is there a setting for ignoring this for let's say 20 first seconds after turning on the heating? I also have my gear in the basement where it's 12-15C so I would have this problem basically everytime I'm going to use it.
Posted: Wed Dec 21, 2016 9:48 pm
by pswindler
i changed it in the firmware to 12 degrees, but it is risky because you dont want to lower more than the amount that the printer will realize the thermister is disconected for unpluged and overheat your printer. When i unplug my thermisters it shows 7 degress so i could go to 10 but i wanted a bigger safety margin.
