Things I have tried:
-Checked for pucks: Haven't seen any since using the PTC tool method.
-Cleaning out nozzle with guitar string: Seems to help get one or two prints out of it before it clogs again.
-Replacing nozzle
-Full Extruder rebuild (cleaned out heat break, new nozzle, flipped heat sink): Did this after I blew a thermal fuse trying to get the filament to flow nicer
-The procedure outlined [url=https://seemecnc.zendesk.com/hc/en-us/articl ... ament--JAM]HERE[/url]with the PTC tool
-Printing at hotter temperatures: Doesnt seem to affect the issue.
-Verified temperatures with thermocouple
-Sliced at 0.4mm, helped a little, but not enough to matter.
-Swapping Extruders: Using another HE280 that belongs to another printer, and printing using the same filament, with the same gCode, the same bowden tube, and the same setup seems to solve the issue, but that extruder is needed elsewhere.
-Retracting at 35 mm/s for 1.8 mm.
Result of Cold Pull (Strongly suspect that the wider diameter shift may be the actual cause of the "clog"):
[img]http://i.imgur.com/eFUsyvo.jpg[/img]
Slicing at 0.5mm
[img]http://i.imgur.com/l9RFwBj.jpg[/img]
Slicing at 0.4mm
[img]http://i.imgur.com/Uum15YV.jpg[/img]
Only "Successful Print". Snapped due to underextrusion.
[img]http://i.imgur.com/Y8Eyksg.jpg[/img]
Things I suspect:
-My PTC retainer may be damaged. It seems to hold the bowden tube in place pretty snugly, and the mark on the tube doesnt seem to move too much when printing.
-I have yet to retrofit to the EZR Extruder, but since a different HE280 worked, I dont think this is the problem.
-I strongly suspect that the barrel fan may be bad. This would be supported by the accumulation of thicker filament above the heater block, and would also explain why the thermal fuse blew despite only being told to heat the printer to 240C. Upon removal and testing, it seems to be vibrating badly.
Thoughts? Any insight anyone can provide would be much appreciated!
