Will there be offered a 5 inch Touch Screen Controller Kit offered for the Max V3 machines that have been upgraded to V3.2?
Thanks.
Bob O.
5" touch screen for upgraded V3 machine
- Plasticator
Re: 5" touch screen for upgraded V3 machine
The screen kit for the 3.2 will work, you'll just need to drill some mounting holes for the LCD mount and a hole for the cabling to pass through.
- Plasticator
Geneb,
Thanks for your reply.
If SeeMeCNC was not coming out with a kit, drilling holes was one of my options. The other option I was thinking of was to modify the Rev B Frame mounting post, remove the ears, add a threaded section to go through either the webcam or second extruder hole and make a matching nut to secure it to the top. This option would not require drilling holes but it would require longer cables.
Also I thought I read somewhere that SeeMeCNC was coming out with an upgraded set of carbon arms for the V3?
Bob O.
Bob O.
I have an enclosure so I made this. An added benefit is that no drilling will be required, you just need to make/come up with longer cables.
https://www.thingiverse.com/thing:2986057
- Plasticator
PengLord,
Thanks, looks good. Where did you buy the $6 cable?
I would like to reposition the 5" display on my Artemis, are there any extension cables readily available (6 or 12" would work for me... I'd need both cables)
Thanks
Thanks
I bought a 1m ribbon cable on Amazon and it worked fine. I ended up buying some new connectors and cut it down to a more appropriate size.ROvermeyer wrote:PengLord,
I'd recommend just buying the connectors and a spool of cable if you have any possible future need
