Here is the latest information on this issue:
I shut down the WiFi with M552 S0
I re-sent M587 with S"studio" P"password" I10.0.0.89 J10.0.0.1 K255.255.255.0
Then:
m552 S1
ok
m552
WiFi module is connected to access point studio, IP address 10.0.0.89
ok
m553
Net mask: 255.255.255.0
ok
m554
Gateway: 10.0.0.1
ok
I pinged 10.0.0.89 and got a reply average of 52ms
I shut down Artemis and pinged 10.0.0.89 again and got no reply
I restarted Artemis and pinged 10.0.0.89 and got a reply average of 56ms
I went to Chrome and opened a new tab and entered 10.0.0.89 and got "No webpage was found for the web address:
http://10.0.0.89/
Here are some reports:
m408 S1
{"status":"I","heaters":[2000.0],"active":[0.0],"standby":[0.0],"hstat":[0],"pos":[0.000,0.000,0.000],"sfactor":100.00,"efactor":[],"babystep":0.000,"tool":0,"probe":"0","fanPercent":[0.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00],"fanRPM":0,"homed":[0,0,0],"msgBox.mode":-1,"geometry":"cartesian","axes":3,"volumes":2,"numTools":0,"myName":"My Duet","firmwareName":"RepRapFirmware for Duet WiFi"}
ok
m408 S2
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[],"xyz":[0.000,0.000,0.000]},"currentTool":-1,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00],"speedFactor":100.00,"extrFactors":[],"babystep":0.000},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":2000.0,"active":0.0,"state":0,"heater":0},"current":[2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,0,0,0,0,0,0,0],"heads":{"current":[],"active":[],"standby":[],"state":[]},"tools":{"active":[],"standby":[]},"extra":[{"name":"MCU","temp":34.0}]},"time":333397.1}
ok
m408 S4
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[],"xyz":[0.000,0.000,0.000]},"currentTool":-1,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00],"speedFactor":100.00,"extrFactors":[],"babystep":0.000},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":2000.0,"active":0.0,"state":0,"heater":0},"current":[2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,0,0,0,0,0,0,0],"heads":{"current":[],"active":[],"standby":[],"state":[]},"tools":{"active":[],"standby":[]},"extra":[{"name":"MCU","temp":33.9}]},"time":333411.1,"currentLayer":0,"currentLayerTime":0.0,"extrRaw":[],"fractionPrinted":0.0,"firstLayerDuration":0.0,"firstLayerHeight":0.00,"printDuration":0.0,"warmUpDuration":0.0,"timesLeft":{"file":0.0,"filament":0.0,"layer":0.0}}
ok
m408 S5
{"axisMins":[0.00,0.00,0.00],"axisMaxes":[230.00,210.00,200.00],"accelerations":[500.00,500.00,20.00,250.00,250.00,250.00,250.00,250.00,250.00,250.00,250.00,250.00],"currents":[0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00],"firmwareElectronics":"Duet WiFi 1.0","firmwareName":"RepRapFirmware for Duet WiFi","firmwareVersion":"1.19.2","dwsVersion":"1.19","firmwareDate":"2017-11-01","idleCurrentFactor":30.0,"idleTimeout":30.0,"minFeedrates":[15.00,15.00,0.20,2.00,2.00,2.00,2.00,2.00,2.00,2.00,2.00,2.00],"maxFeedrates":[100.00,100.00,3.00,20.00,20.00,20.00,20.00,20.00,20.00,20.00,20.00,20.00]}
ok
m122
=== Diagnostics ===
Used output buffers: 1 of 32 (9 max)
=== Platform ===
RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
Board ID: 08DGM-95BNL-MGPSJ-6JKFG-3SJ6Q-T1W7Y
Static ram used: 21176
Dynamic ram used: 95552
Recycled dynamic ram: 2056
Stack ram used: 4056 current, 5364 maximum
Never used ram: 6924
Last reset 92:39:54 ago, cause: power up
Last software reset reason: User, spinning module GCodes, available RAM 6400 bytes (slot 3)
Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 30.0MBytes/sec
SD card longest block write time: 0.0ms
MCU temperature: min 33.5, current 33.8, max 40.2
Supply voltage: min 0.5, current 12.1, max 12.4, under voltage events: 3, over voltage events: 0
Driver 0: standstill
Driver 1: standstill
Driver 2: standstill
Driver 3: standstill
Driver 4: standstill
Date/time: 1970-01-01 00:00:00
Slowest main loop (seconds): 0.031250; fastest: 0.000000
=== Move ===
MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Bed probe heights: 0.000 0.000 0.000 0.000 0.000
=== Heat ===
Bed heater = 0, chamber heater = -1
=== GCodes ===
Segments left: 0
Stack records: 0 allocated, 0 in use
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "m122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
autopause is idle in state(s) 0
Code queue is empty.
Network state is running
WiFi firmware version 1.19
WiFi MAC address 2c:3a:e8:0b:2b:ef
WiFi Vcc 3.10, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 40472
WiFi IP address 10.0.0.89
WiFi signal strength -53dBm
Reconnections 0
HTTP sessions: 0 of 8
Socket states: 0 0 0 0 0 0 0 0
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
ok
I am at a loss for the next step.
Your help will be greatly appreciated.
