Artemis Linear Rail Mainentance
The one, the only, the Atremis. Forum for the monster metal machine from SeeMeCNC
PartDaddy
Post by PartDaddy »
Ok, we've tested a huge number of lubricants on the Artemis linear rails and this is turning out to be the best. Only started using it today, but right after applying several drops, this oil is performing noticeably better than other lubricants.
Wipe rails, apply several drops above carriage on both sides of the rail in the groove where the balls roll. Manually work carriage up and down.
Wiping Artemis linear rail groves and applying a few drops of this oil should be a 4 to 8 week maintenance chore. Use judgement based on humidity in the environment you're using your machine.
PTFE Oil
PTFE Oil
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
RegB
Re: Artemis Linear Rail Mainentance
Post by RegB »
I had used a "donated" make-up eyebrow brush to put a little grease into the slots where the balls ride.
Given the diameter of the balls they will pick up a decent film and distribute it to the rest of the rails if you (for example) just run the bed leveling program.
I doubt that I can ever get that grease out now, without tearing everything apart.
So although the 3-in-1 with ptfe may be "better" at this stage the delta improvement may not be worth it (for me).
RegB
Post by RegB »
The test print in this thread;
http://forum.seemecnc.com/viewtopic.php ... 32#p109532
Showed up my need for a little rail maintenance.
I greased the "faces" of the rails, as well as the slots that the balls ride in, I ran the head up and down a few times to spread it around.
I had not previously lubed the rail faces, not absolutely sure that I needed to, but I mention it as a possible factor.
I STRONGLY RECOMMEND this test print to everyone as a regular maintenance check, it showed up a friction condition that was causing a mechanical stutter/chatter.
Nothing I could hear, but something that showed up on this print and lubrication was the ONLY change I made between the fault being there and being gone.
nurbie
Post by nurbie »
Gun Butter, I think it's all the same formulation.
Personally tested on MTB UltraEndurance rides and semi-automatic weapons.
Super bueno! Clean, thin film lubricant.
Send me an Artemis and I'll test it ;)
(might take a while...)
https://gunbutter.com/
WOAH/daym/urp
price went up a bit since 2003 when I bought a few!
The new revision of the Artemis doesn't use the linear rails.
nurbie
Post by nurbie »
Thank goodness!
Return to “Artemis”
