Base fan upgrade for quietness
Posted: Thu Apr 11, 2019 9:46 am
OK maybe I'll start this forum off with what i just did for my V4 last night, mentioned in a troubleshooting thread.
Andy suggested this fan for quietness since I had asked for options to quiet down the hairdryer noise in the base of the V4, just about my only complaint with the unit!
Noctua A6x25 fan: https://www.amazon.com/gp/product/B009N ... UTF8&psc=1
It's a 3-pin fan but I used one of the adapters (so as not to cut the pigtail from the fan itself, just in case it didn't work or something) to just get red and black to the existing connector in the base.
How to:
- turn off and unplug the machine, especially since you'll be working so close to the PS
- remove the plastic corner shields (they just pull out) on either end of the fan side of the base
- reach around and hold the locknuts with pliers or a wrench while unscrewing the fan mounting bolts; make sure you get the washers as well as the nuts. if you get little rubber grommets as well you don't necessarily need to reuse them as the Noctua fan has rubberized corners
- lift the flaps on the Wago connector to pull out the red and black wires to the fan (the other side of each pair is where the wires come in from the PS)
- on the Noctua fan, either using the regular 3 pin tail or the 4-pin adaptor (I did that), cut the end off and open the sheathing until you have access to red and black wires
- then strip about 1/2-3/4 inch of casing off - be VERY careful, there are only a few strands of actual wire inside and I broke the black one just twisting the strands together.
- bolt the fan in place and lift the Wago flaps again to insert the red and black stripped ends.
- plug in, turn on, tune in and drop out... wait.... lol
- hopefully your new quiet breeze soothes you. I know it did for me! Feels like it pushes almost as much air as the stock fan, but I have no way to really test that.
Pics: here is the pigtail with the connector that i cut and stripped - if I screwed that up I could use another connector or cut the pigtail itself so this gave me lots of chances just in case And it was just impossible for me to get a photo with the black wire visible going from the fan wire to the wago connector, but it goes under the righthand paddle with no lettering on it, next to the labeled paddle with the black PS wire. Tadaaaa. Now I guess I'll have to tackle the fans on the effector for maximum silence =0)
How to:
