I have been playing around. When I set layer height to 0.04 then the z retract is 0.04:
; layer_height = 0.04
; perimeters = 3
; solid_layers = 3
; fill_density = 0.4
; nozzle_diameter = 0.4
; filament_diameter = 3
; extrusion_multiplier = 1
; perimeter_speed = 45
; infill_speed = 60
; travel_speed = 150
; scale = 1
; single wall width = 0.42mm
M104 P200 ; set temperature
G28 ; home all axes
M109 P200 ; wait for temperature to be reached
G90 ; use absolute coordinates
G21 ; set units to millimeters
G0 Z0.040 F9000.000
But that would make the layers way to small, right?
z offset
Re: z offset
You are specifying a layer height of .04mm, retraction is something different, it is under retract settings. The Gcode you posted above is the starting Z height, because layer 1 would be at .04, layer 2 at .08 etc....
Re: z offset
Thanks,
I'm so glad you are here. Only one thing left, learning how to check the temp on the hot end and we can start printing!!!!
Thanks again.
Thanks again.
