first off this isn't a super fine tuned profile it still needs a few tweeks but its a good starting point for the eris any changes to this profile please be willing to share them as I will do also happy printing eric leake
; KISSlicer Profiles Backup: Wed Nov 15 08:05:46 2017
; ---=== PRINTERS ===---
[eris]
bed_STL_filename=
MRU_style=eris
MRU_support=eris
MRU_material=basic eris
extension=gcode
cost_per_hour=0
g_code_prefix=3B205B6D6D5D206D6F64650A4732310A3B204162736F6C75746520706F736974696F6E206D6F64650A4739300A3B204162736F6C757465204578747275646572206D6F64650A4D38320A3B2053746172742068656174696E6720746865204265640A4D31343020533C4245443E0A3B20486F6D652074686520617865730A4732380A3B20576169742074696C6C2074686520426564206973206865617465640A4D31393020533C4245443E0A3B20486561746564206368616D62657220472D636F6465206973206E6F7420756E6976657273616C0A3B4D31343120533C424F583E0A3B4D31393120533C424F583E0A
g_code_preheat=NULL
g_code_warm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
g_code_same_warm=3B204D6F766520746F20746865207374617274206F6620746865206E65787420706174680A473120583C4E455854583E20593C4E455854593E2046363030300A47342050300A3B2053616D652065787472756465722C207761726D20616E6420776169740A4D31303420533C54454D503E0A4D31303920533C54454D503E
g_code_same_cool=3B2053616D652065787472756465722C20636F6F6C20286E6F2077616974290A47342050300A4D31303420533C54454D503E0A
g_code_cool=3B2053616D652065787472756465722C2061626F757420746F20646573656C6563742C206D617962652072657472616374206265666F726520636F6F6C696E6720646F776E0A3B2052455452414354204845524520494620594F552057414E540A47342050300A4D31303420533C54454D503E0A
g_code_N_layers=NULL
g_code_postfix=3B20416C6C206578747275646572732061726520726574697265640A3B204D6F7665207468652068656164207570202F2062656420646F776E0A4739310A4731205A2B31300A4739300A3B207475726E206F666620746865206265642026206368616D62657220286D616368696E65207370656369666963290A4D3134302053300A3B4D3134312053300A3B2046494C4C205448495320494E204153204E4545444544
g_code_pause=3B205061757365207468656E20526573756D650A3B20757375616C6C79204D3020287479706963616C29206F72204D3120286C65737320636F6D6D6F6E29206F72204D32323620286C6561737420706F727461626C65290A4D300A
every_N_layers=0
post_process=NULL
num_extruders=1
firmware_type=2
add_comments=1
g4p_uses_seconds=0
fan_on=M106
fan_off=M107
fan_pwm=1
add_m101_g10=0
z_speed_mm_per_s=5
z_settle_mm=0
bed_size_x_mm=124
bed_size_y_mm=124
bed_size_z_mm=165
ext_radius=0
bed_offset_x_mm=0
bed_offset_y_mm=0
bed_offset_z_mm=0
bed_roughness_mm=0
round_bed=1
travel_speed_mm_per_s=75
rim_speed_mm_per_s=150
first_layer_speed_mm_per_s=15
dmax_per_layer_mm_per_s=15
xy_accel_mm_per_s_per_s=1500
xy_steps_per_mm=200
lo_speed_perim_mm_per_s=10
lo_speed_loops_mm_per_s=15
lo_speed_solid_mm_per_s=20
lo_speed_sparse_mm_per_s=25
hi_speed_perim_mm_per_s=20
hi_speed_loops_mm_per_s=25
hi_speed_solid_mm_per_s=30
hi_speed_sparse_mm_per_s=30
top_raft_speed_mm_per_s=20
bottom_raft_speed_mm_per_s=10
ext_gain_1=1
ext_1_mat_name=basic eris
ext_axis_1=0
ext_gain_2=1
ext_2_mat_name=basic eris
ext_axis_2=0
ext_Xoff_2=0
ext_Yoff_2=0
ext_gain_3=1
ext_3_mat_name=basic eris
ext_axis_3=0
ext_Xoff_3=0
ext_Yoff_3=0
ext_gain_4=1
ext_4_mat_name=basic eris
ext_axis_4=0
ext_Xoff_4=0
ext_Yoff_4=0
heat_time_coef_1=0.0015
nozzle_dia_1=0.5
nozzle_len_1=0
drive_len_1=0
heat_time_coef_2=0.0015
nozzle_dia_2=0.5
nozzle_len_2=0
drive_len_2=0
heat_time_coef_3=0.0015
nozzle_dia_3=0.5
nozzle_len_3=0
drive_len_3=0
heat_time_coef_4=0.0015
nozzle_dia_4=0.5
nozzle_len_4=0
drive_len_4=0
model_ext=0
support_ext=0
support_body_ext=0
raft_ext=0
ext_order_optimize=0
solid_loop_overlap_fraction=0.1
min_seg_len_mm=0
z_step_mm=0
max_nodes_per_s=0
profile_date=2017-11-15 08:05:46
; ---=== MATERIALS ===---
[basic eris]
linked_printers=eris
g_code_matl=NULL
g_code_matl_custom=NULL
matl_user_notes=4D6174657269616C2050726F66696C652057697A6172640A3E204D6174657269616C3A20504C410A3E2046696C616D656E74206469616D65746572203D20312E3735205B6D6D5D0A3E20457874727573696F6E2074656D7065726174757265203D20323030205B435D0A
fan_Z_mm=1.5
fan_loops_percent=40
fan_inside_percent=40
fan_cool_percent=50
temperature_C=200
keep_warm_C=150
first_layer_C=200
bed_C=0
chamber_C=0
preheat_strategy=3
flow_min_mm3_per_s=0.1
flow_max_mm3_per_s=10
flow_cool_mm3_per_s=1
destring_length=3.5
preload_factor=0
matl_viscosity_over_elasticity_us=0.75
destring_min_mm=2.5
destring_trigger_mm=10
preload_speed_mm_per_s=25
destring_speed_mm_per_s=30
Z_lift_mm=0.1
min_layer_time_s=10
wipe_mm=1
cost_per_cm3=0.04
flowrate_tweak=0.9
fiber_dia_mm=1.75
shrink_percent_xy=0
shrink_percent_z=0
color=0
; ---=== STYLES ===---
[eris]
quality_percentage=100
layer_thickness_mm=0.15
max_layer_thickness_mm=-67
first_layer_thickness_mm=-50
unsupported_stepover_mm=-50
extrusion_width_mm=0.5
num_loops=4
skin_thickness_mm=0.875
infill_extrusion_width=0.5
infill_density_denominator=4
stacked_layers=1
use_corners=0
force_joint_layers=0
loops_insideout=1
join_perimeter_loop=1
infill_st_oct_rnd=1
inset_surface_xy_mm=0
seam_jitter_degrees=360
seam_depth_scaler=0.3
seam_gap_scaler=0.2
seam_angle_degrees=85
crowning_threshold_mm=1
; ---=== SUPPORTS ===---
[eris]
support_sheathe=0
support_density=0
use_lower_interface=0
solid_interface=0
support_inflate_mm=0.5
support_gap_mm=-100
interface_gap_mm=-100
support_angle_deg=50
support_z_max_mm=-1
sheathe_z_max_mm=2.5
raft_mode=0
prime_pillar_mode=4
pillar_placement=3
raft_inflate_mm=3
raft_hi_stride_mm=1
raft_hi_thick_mm=0.25
raft_hi_width_mm=0.5
raft_lo_stride_mm=2
raft_lo_thick_mm=0.5
raft_lo_width_mm=1
brim_mm=2
brim_ht_mm=0
brim_gap_mm=0
brim_fillet=0
interface_band_mm=1
interface_Z_gap_mm=0.2
first_Z_gap_mm=0
raft_interface_layers=5
raft_interface_bond=0
brim_latch=0
interface_angle_deg=30
interface_stride_mm=0.75
interface_width_mm=0.375
interface_1st_layer_width_mm=0.5625
eris profile
eris profile
- _KS_backup_profiles.ini
- (6.3 KiB) Downloaded 226 times
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Software
- ↳ AutoDesk 123D
- ↳ OpenSCAD
- ↳ Blender
- ↳ Sculptris
- ↳ SolidWorks
- ↳ FreeCAD
- ↳ Other
- ↳ OctoPrint
- ↳ Mach3 Software
- ↳ EMC2/LinuxCNC
- ↳ Slic3r
- ↳ Skeinforge
- ↳ KISSlicer
- ↳ Cura
- ↳ Repetier Host
- ↳ Simplify3D
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
