Just uploaded my standard slicing profile. Funny that this just launched, I was thinking about the need that this fills a lot recently. I did a jotform survey a long time ago and was maintaining a (very small) collection of responses, and on my MakerSpace's home forum I just made a sticky thread to dump settings and profiles in (
http://makerhive.proboards.com/thread/8 ... -materials" onclick="window.open(this.href);return false; ). I hope that your platform becomes a great resource for our community, we definitely need it!
A tip... where you have the checkboxes for supports and brim, a third variant called a raft is pretty common.
You may also want to have a drop down for nozzle diameter because that will be an important filtering criteria when there are a lot more entries. Here's my brain dump on the things you might want to collect and be able to filter by:
Nozzle diameter
Print Temperature
Heated bed yes or no (and temp?)
Delta or Cartesian (or other, there are polar machines and all kinds of other ones out there)
Some of them matter to slicers, and some of them are just in the generated GCode based on the printer settings that you specify in that particular program.
Another idea: If you can tease out a list of settings that are the same across all of the slicing platforms (nozzle diameter, temperature, speed, retracts, infill, etc) it would be cool to make a slicing profile creator or converter to make it easier to try other programs. For example, I use Cura and have it dialed in pretty well. If I wanted to try Craftware as a test, I'd have to manually enter all of my Cura settings which is tedious and error prone (plus some of the same settings have slightly different labels). It would be awesome if I could say "these are my settings, give me a config file for slicer x" and generate them on the fly and switch between them that easily.
