Just thought I'd try and give back a little.
Save all those small pieces you pop out, don't take much room and there is always a use for them such as-
The wires coming out of the bottom of the towers, it seems they tend to rub on the pulleys.
We dremeled our down- how much depends on the wire gauge and used them to push up against the wires to keep them off the pulley.
There is enough tension to keep them in, but you can get them back out if needed.
I know no one will see this part, but I've been called a__l more than once.
[img]http://i381.photobucket.com/albums/oo254/TheOriginalTwoTone/DSC00967.jpg[/img]
[img]http://i381.photobucket.com/albums/oo254/TheOriginalTwoTone/DSC00969.jpg[/img]
New builders
Re: New builders
Great idea. I do stuff all the time like that that no one will see but I know it is there. Seems the right thing to do.
Re: New builders
Very cool - thanks for the tip!
Rostock Max V2. E3D V6 Hotend. E3D Titan Extruder. TrickLaser Carbon Fiber 300mm Arms. TrickLaser MaxMetal Platform. TrickLaser Trick Trucks. TrickLaser Heat Spreader. TrickLaser LED Light Ring. MeanWell SP-500-24. Simplify3D.
