Artemis 300 Simplify3D Profile
Posted: Mon Oct 18, 2021 9:54 am
Hey everyone,
I've been using this profile for quite awhile; I was hesitating to share it because I use a larger nozzle but then I realized that people will still find this useful to tweak.
Attached is a Simplify3D profile that I have tested and validated extensively. It supports dual extrusion and I have tested it with changeovers during a print as well. It is currently set to a 1mm nozzle diameter but to change it to the standard .5 I would adjust these settings:
.5mm nozzle
Flow rate of 1.0
Layer heights of .4, .3, .2 (you can mess with these to go lower if you want).
Slowly move speeds up from 25mm/sec to your desired speed.
Increase fan speed. Mine right now is set to 0.
Tested filaments:
PLA
TPU
PETG*
YogaFlex*
*Require further tweaking.
This is the profile I used to mass manufacture my custom 3D printed respirators: https://elevons.design/masksquared/, so you can see a use case here (made with TPU).
Hope this helps!
.5mm nozzle
Flow rate of 1.0
Tested filaments:
PLA
TPU
PETG*
YogaFlex*
Hope this helps!
