Thanks for sharing your lessons learned by having a slow retracting time. One thing I notice in the few months that I have been at this, is not having the slicer config files consistent. I started with the download from the Seemecnc site but played around with the location of where to keep them to get them to work. Then after a RH software update they had to be reset and now the RH just stopped working. When I reset the config files the reverted back to a 5.4mm retraction at 100mm.mhackney wrote:I'm perplexed why folks are having issues and turning to canola oil. What are you retract settings - length AND speed? My experience (and I've been on the soapbox about it for 2 years now) is that a fast retract (anything greater than say 25 mm/s with a 1/75mm filament) are BAD BAD BAD for PLA. I run at 20mm/s and 1.5mm retract and have printer 1000s and 1000s of hours and meters of PLA for almost a year no with NO plugging or issues. Perfect prints every time. If I change retract to 35mm/s I guarantee I'll have a problem.
As far as this thread and the canola convert, I can see its merits for a faster retraction. The melted plastic is sticking to the hot end and when changing direction of the flow with the sticking properties of the plastic and hot end will cause the jam. Slowing things down has worked for you, but with some lubrication between the hot end sides and the plastic pool inside, faster retractions may be able to be achieved.
I am thinking of purchasing a spray can of Tungsten Disulfide Nano-Lubricant to put into a new end to see if this would be beneficial. For now I have slower settings and Canola.
