Hey there friend! Happy to see you posting on the board! According to SeeMeCNC, the Lexan panels you mentioned won't be available on sale for a few weeks - consider yourself lucky! I look forward to using a flexible build surface.Nomasfilms wrote:Although I've only done one print, the Lexan build plate supplied by SeeMe was amazing. At 75C the ABS stuck like glue, and after cooling, you can remove the Lexan and simply flex slightly. POP and it's off! It's almost too simple. No noticeable residue or damage to the plate that I can see. Buy a few, and you can rotate them...
FYI, after reading this thread and several others, I was really concerned about my build surface. I found the middle would bow up by around 0.25 to 0.5 mm. I compensated for this by calibrating the adjustment screws using a thick piece of card stock directly in front of each rail. Once my G1 Z0 was just close enough to grip the card, I'd switch to another rail. I'd finish my testing by using a piece of thin printer paper and testing the center of the board.
I believe by using a thicker card stock (instead of thin paper) for calibrating at the rails, I can compensate for the very slight warping on my bed. So far all my prints since calibrating in this manner have been very promising - I have had no issue with delamination of the first layer.
