problem on z axix
problem on z axix
My eris delta 3d printer somehow works on the last couple of days but he can not build on z axix properly and i attached a picture to clearly show the problem. What is wrong and how to fixit, solutions please if you have them!! thank you indeed.
- lightninjay
Re: problem on z axix
It appears as though your image did not post properly.
If you are having Z axis issues, assuming that it is a problem with layer alignment, check the tension of your belts and that the umbilical cable can not snag on any of the arms.
Once the image is posted, diagnosis of your problem will be much easier.
