I have RostockMAX, the original, lets call it V1 - purchased it sometimes 3.5 years or so ago as a kit that I've assembled and was working very well!
I ordered the upgrade kit for the new HE280, a week ago, and I had to change everything from Cheapskates all the way to the new HE280
My Rambo is old - v1.1b
I've downloaded the newest Firmware from here on Sunday, V0.92.2 and installed it - no problem - and I made no other changes but the direction of Z - please see bellow.
I did not plug or unplug any wires for the End Stops or to the Nema motors.
I also made sure that I had no static charge before I touched anything around!
I followed the instructions how to connect the wires to the socket, that plugs into the HE280 (I had my good friend Hari help me, just to make sure that we measured everything several times before cutting existing wires and after I soldered the wires ...)
When I powered up the first time, the Z was going down, not up, -BUT the X and Y did NOT MOVE AT ALL!- so I had to change the #define INVERT_Z_DIR from 1 to 0 [Thank you Wade Wendorf!] (I've learned that this is normal)
BUT I was not able to get my Y and X to work at all! They also aren't LOCKED (what I mean is that the Z tower can't be moved by hand at all, the Nema is engaged, or what ever is the correct name for it, so I can't push the Z UP or DOWN), BUT the Y and X are FREE TO MOVE, just like if my printer isn't turned on at all!
The second observation I've made is that under the old Firmware, my LCD booted fast, but now sometimes is as fast as it was before, but many times it is MUCH SLOWER to boot! Have anyone out there noticed such a problem? - if it is a problem, I do not know....-
When I used the MatterControl, I wanted to see if I can move the XYZ, but only Z responds not the X or Y!
Remember, this printer was working fine under the older version Firmware, 0.92.x (I do not remember what was before the 0.92.2, sorry)
The bed preheats just fine, the HotEnd Fan is on all the time, the Hot End works fine, but I can't HOME from the LCD at all or from the MatterControl!
At this point I do not know what else I can try and I'm open to any suggestions.
Thank you all in an advance!
Tony
UPGRADE PROBLEM with X and Y now not working
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Software
- ↳ AutoDesk 123D
- ↳ OpenSCAD
- ↳ Blender
- ↳ Sculptris
- ↳ SolidWorks
- ↳ FreeCAD
- ↳ Other
- ↳ OctoPrint
- ↳ Mach3 Software
- ↳ EMC2/LinuxCNC
- ↳ Slic3r
- ↳ Skeinforge
- ↳ KISSlicer
- ↳ Cura
- ↳ Repetier Host
- ↳ Simplify3D
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
