So, meanwhile, I stumbled onto a neat Cartesian robot from craigslist -- and bought it -- I'll post some pictures when I get a chance. -- It's super weird and unique -- it has an acrylic tank that the head moves around in, and a drain -- presumably it can be filled with water (no tooling mounted -- previous owner says it was for ultrasonic inspection) -- the head is all driven by metal "belts" (more like wires) and pulleys and stuff. It's brand is "Multidata" but I can't find a model or anything number anywhere. I'm guessing it was made between the late 70s and mid 80s (probably before the 90s...?).
Its movement area is just under 2' cubed.
I was thinking about turning it into a 3D printer (if I ever finish my H-1 build -- because you could fit a lot of print heads in there) or maybe printing a Dremmel mount for it, and using it as a milling machine if it can handle the force.
I've got a couple of issues -- one is, the Y axis is a little janky, but that I'm just going to have to work out -- more pressing, it has it's own electronics already, and a Male DB25 port -- I suspect that it's actually a serial host port and not a printer port (when I hook up my RS232 kit, I can see negative voltages on some of the RS232 specific pins, I don't think printer ports would do that...). -- Figured that since it's male, it must be a host port and not a client port, so I made a null modem DB9-DB25 host to host cable and hooked 'er up.
Unfortunately, I'm not really sure where to go from there -- I pulled the thing up in hyper terminal at 9600 baud, no parity, simple settings, and It will sometimes send back binary data if I mash on the keyboard a bit -- mostly FF, FE, and a few others... If I move the head around with the toggle switches it doesn't send any binary data back to the main PC.
TL;DR:
Are there any well known binary serial/RS232 protocols for working with old-as-hell CNC machines?
Are there any programs for serial/RS232 CNC machines that I could try and see if they "Just work"?
My main goal right now is just figuring out how to move the head via software. I would hate to have to replace perfectly fine electronics.
Weird Craig's List CNC Machine I picked up...
- BrainSlugs83
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Software
- ↳ AutoDesk 123D
- ↳ OpenSCAD
- ↳ Blender
- ↳ Sculptris
- ↳ SolidWorks
- ↳ FreeCAD
- ↳ Other
- ↳ OctoPrint
- ↳ Mach3 Software
- ↳ EMC2/LinuxCNC
- ↳ Slic3r
- ↳ Skeinforge
- ↳ KISSlicer
- ↳ Cura
- ↳ Repetier Host
- ↳ Simplify3D
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
