Heated bed temp
Check out how others are building and modding their own heated beds
Dave_Sohlstrom
Heated bed temp
Post by Dave_Sohlstrom »
What temp are the folks with heated beds running at.I am shooting for 100C. I am running a 75 watt heating pad designed to go on the pan of an engine. Temp comes up slowly and I think I will get to 100C. Right now 16 min into the print I am at 92.
Dave Sohlstrom
H-1 Tank
Leeway
Re: Heated bed temp
Post by Leeway »
Sounds like you could do with a larger power supply, amp wise.
Mine is a 30 amp supply and it gets the bed to 110 C in a couple minutes.
Lee
michaellatif
Re: Heated bed temp
Post by michaellatif »
I have my heated bed running between 130C - 140C because the glass plate for some reason causes a 20C drop in temp, so I get about 110C - 120C on the surface. The bed draws about 4 amps @ 12v and heats up in roughly 15 minutes. The hotter the bed the better the ABS sticks and stays flat (from what I found).
Mike Latif
H-1 #3
Re: Heated bed temp
I run mostly PLA, so I rum at 60, glass plate is only causing about 2-5 degrees drop for me.
Most people printing ABS seem to be running >>100, but it's hard to know if that's thermister temperature or top of glass temperature.
Leeway
Re: Heated bed temp
Post by Leeway »
I have just started using the heat with the pla. I use it at about 55c. When I was doing ABS a few weeks back, I used 110 C on it. The top of the glass was just a few degrees different. I am using 1/4" pyrex type glass. It transfers the heat pretty well, but ambient temp in the house does cool the top a bit.
Lee
Re: Heated bed temp
Leeway wrote:I have just started using the heat with the pla. I use it at about 55c. When I was doing ABS a few weeks back, I used 110 C on it. The top of the glass was just a few degrees different. I am using 1/4" pyrex type glass. It transfers the heat pretty well, but ambient temp in the house does cool the top a bit.
Does anyone know if the pyrex glass can be cut? I want to cut a small slot on one end for the wires maybe with a dremel diamond wheel.
Thanks if anyone knows for sure.
michaellatif
Re: Heated bed temp
Eaglezsoar wrote:Does anyone know if the pyrex glass can be cut? I want to cut a small slot on one end for the wires maybe with a dremel diamond wheel.
Unfortunately you can't. The glass is not meant to be cut or drilled by us (unless you have a precision water cooled diamond saw), it just breaks or cracks.
Mike Latif
H-1 #3
Leeway
Re: Heated bed temp
Post by Leeway »
Right. It doesn't act like tempered glass that will just shatter instead of cracking. Mine had a chip in the corner when it arrived, but is still okay. If that were tempered, it would have shattered. Maybe a nice tile saw could cut it, but any mistake could be costly. :(
Lee
Re: Heated bed temp
McMaster Carr is sort of expensive for this glass, do you know of a less expensive source?
michaellatif
Re: Heated bed temp
That's the only place I could find, but I only did a limited/simple search.
I did find a source a bit cheaper that is local to me that will cut custom sizes, unfortunately its a 2.5 hour drive. . . one way :-/.
Anyone else have a good source? I have a need to get a 8"x8" piece for another printer.
Mike Latif
H-1 #3
Dave_Sohlstrom
Re: Heated bed temp
Well my heated bed with 75 watts at 12 volts is working good. It does take a little time for it to get to temp but I am retired and not going any where so I can live with it. It is nice to have parts with flat bottoms. I have some big parts that need printing so will see how it does on those.
Dave Sohlstrom
H-1 Tank
skrubol
Re: Heated bed temp
Post by skrubol »
Leeway wrote:Sounds like you could do with a larger power supply, amp wise.
Unless his supply is crowbarring or cutting out, he needs more volts, not amps. Whether he's got an 12v 8A supply or 12v 30A supply, if the heater only draws 6A, it's going to heat up at the same rate with either.
Leeway
Re: Heated bed temp
Post by Leeway »
That isn't my experience with a heat bed. Initially I used a 24 VDC supply that is rated at 3A. It was slow to heat.
The 12 VDC 30 A heats fast. I'm not an electrician or electrical or electronics engineer. Just relating my experience with the Prusa heat bed.
Lee
skrubol
Re: Heated bed temp
Post by skrubol »
Your 24v supply was probably tripping. Was probably only actually on a small amount of the time. If the bed was made for 12v, 75W, at 24v it would pull around 12A. No way a little 3A power supply is going to hold up to that.
Leeway
Re: Heated bed temp
Post by Leeway »
I don't understand all the things about it. I know the 24 VDC is a Condor linear supply and the 12 VDC can be adjusted some and is a switching type. Typical cnc machine supply made in China. Not that the later has any bearing on how it works. Both work well.
I didn't have a meter on it when it was connected, so it very well could have been dropping out intermittently.
Lee
johnoly99
Re: Heated bed temp
Post by johnoly99 »
Leeway, just realized what the shark guard was all about! I actually looked into your guards a few years ago, I think I found you from the cnczone forums maybe? Anyways, just thought I'd say that.
Leeway
Re: Heated bed temp
Post by Leeway »
Thanks, John.
I am a frequent flyer at the Zone. I could not have built all my cnc machines without the members and resources available there.
With the guards, it seems every time I step up production with a new machine, orders increase by the same factor, so there has always been a lead time on those.
That is a good thing for me, not so good for the customers.
I am working on completing my plasma cutter now. Just had it's shed installed last week. That should decrease leads quite a bit.
Nice machines you guys are putting out as well.
I flipped a coin over the Prusa or the H-1 and it was Prusa.
I like the linear bearing version that I have.
Great Forum you guys have started here as well.
It has to be the most used 3D printer Forum I have seen yet and can only get better.
Good luck with it and your business. I'll help when I can. :)
Lee
johnoly99
Re: Heated bed temp
Post by johnoly99 »
This just in! SeemeCNC H-1.1 is almost ready for release. Lunear bush/bearings, lowered hdwr count, faster assembly and more!
tom10122
Re: Heated bed temp
Post by tom10122 »
You mean like a tile cutter? I might wanna look into a heatedbed and i got a tile cutter, water cooled, diamond saw blade
JTCUSTOMS
Re: Heated bed temp
Post by JTCUSTOMS »
Seems to be the one thing my waterjet wont cut, ask me how I know
JTCUSTOMS
michaellatif
Re: Heated bed temp
JTCUSTOMS wrote:Seems to be the one thing my waterjet wont cut, ask me how I know
Ouch. I can only imagine the aftermath.
Mike Latif
H-1 #3
michaellatif
Re: Heated bed temp
tom10122 wrote:You mean like a tile cutter? I might wanna look into a heatedbed and i got a tile cutter, water cooled, diamond saw blade
That will be to rough of a cut breaking the glass. As far as I know there are no consumer grade tools available to be able to cut this glass.
If you do find one or something that will work, let us know! I would love to be able to make custom sized glass plates for my machines.
Mike Latif
H-1 #3
wildideas1
Re: Heated bed temp
Post by wildideas1 »
Thks Lee for the material I am finishing the build out tonight but just cam to the realization I don't have a wiring diagram on the connection from the hotbed Phebe to the vellamen unit can anyone provide the diagram or how to my brain is having a moment today.
johnoly99
Re: Heated bed temp
Post by johnoly99 »
wildideas1, JOhn here. The Phebe has two seperate traces for the 12V connection. Just run the 12V from the velleman to one of the +12V and jumper over to the other +12V on the board. Same for the ground wires. Other than that, thermistor goes on the pad, and wires in same way as the hot end setups.
hsb727
Re: Heated bed temp
Post by hsb727 »
well darn. I melted my h1.1 bed and never got past 95c. Has anyone used aluminum or mdf for a bed? And is the glass above the heated bed or below
--- I know it was a noob move but heck I was just in the thick of the learning curve.. wonder what else I'll melt besides abs
Return to “Heated Bed How-To's”
