[img]https://image.ibb.co/niBBST/Leveling_Yo ... 4x1024.jpg[/img]
Let's auto level your machine through the Duet browser control interface.
You first pull up your machine by entering it's IP address. If you haven't configured your printer yet, follow the configuration guide for your model.
The auto leveling (calibration) routine is a macro run from the control screen. The control screen may be a browser window on your computer or an optional touch screen controller mounted on your machine. SeeMeCNC provides macro's with the firmware found on github.com/seemecnc. Each SeeMeCNC Duet controlled machine has the latest firmware installed at the factory. We ship with release of Duet firmware AND include custom macro's we've written and thoroughly tested for your SeeMeCNC machine.
Typical glass bed cleaning process
1. remove glass bed from the printer
2. clean with dish soap and warm water
3. dry thoroughly and re-install on the printer
4. click the macro "Probe Autolevel" (see picture)
5. machine will finish and tell you the result of the probing
6. you're ready to print again
First Probe macro is normally run once before any other probing after the printer is assembled. First Probe does a mapping routine and is a lengthy, more thorough calibration of your printer. It is not necessary to run this very often at all. If you change something with your arms, linear motion, or frame, you would want to re-run this First Probe macro to calibrate your machine again.
Some Notes
-Try not to touch the glass when removing prints. The oils from your fingers will keep the print from sticking
-Did you know PLA usually sticks great to squeaky clean glass. Clean your glass bed with rubbing alcohol and give it a try
-To make your print stick better, try Magigoo, purple glue stick, or Aquanet unscented hairspray. For best results apply these at room temperature
-It is not necessary to run Autoleveling every time your print.
-see photo "...do not use the button". The reason not to use this button is because we custom write the macro's for each specific 3D printer we manufacture. Clicking the button will not fetch the same results as running the macro we provide for your printer.
-clean the nozzle tip so it is free of any leftover filament stringing
-clear the print bed surface
We continue to update, review, and organize our User & Setup Guides. Our goal is to help new SeeMeCNC users get started with minimal effort and to save you time so you can do more printing!
Thank you,
Steve "PartDaddy" Wygant
(Posted from our blog by Caleb, I'm not Steve. Steve wrote this post )
Bed Leveling Notes for your Duet controlled SeeMeCNC 3D Printer
General info from SeeMeCNC HQ
1 post
• Page 1 of 1
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
1 post
• Page 1 of 1
Return to “General Announcments”
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Software
- ↳ AutoDesk 123D
- ↳ OpenSCAD
- ↳ Blender
- ↳ Sculptris
- ↳ SolidWorks
- ↳ FreeCAD
- ↳ Other
- ↳ OctoPrint
- ↳ Mach3 Software
- ↳ EMC2/LinuxCNC
- ↳ Slic3r
- ↳ Skeinforge
- ↳ KISSlicer
- ↳ Cura
- ↳ Repetier Host
- ↳ Simplify3D
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
