Working Repetier Host Firmware Config
Can anyone post a working repetier firmware configuration.h and pins.h files?
Re: Working Repetier Host Firmware Config
We're just installing Repetier this weekend and should have something soon. What sorts of problems are you having?
What board are you running on?
I am using a RAMBO board. The problem I have is that the Z Axis more or less seizes up when I try to move it in either direction. I don't have this problem using Marlin, so I assume it is something in my configuration. I used the stock Repetier for Rambo files.
