RAMbo reboots during slow prints (<40 mm/s), but works fine in faster prints
Posted: Mon May 20, 2019 2:23 pm
Hello all! I'm having an issue where my Rostock Max V2 reboots during slow prints. I've reproduced it reliably somewhere around <40 mm/s. basically, the printer finishes the skirt just fine at the slow speed, but when it starts the print, it usually can't finish even one layer, (sometimes even a single line) before the printer reboots. It prints just fine at higher speeds, 60-70mm/s (even 125mm/s!), but for some reason printing slow is a challenge. I used to be able to print suuuuper slow about a half a year ago when I was really into printing D&D miniatures, but I'm not sure what could've changed that's managed to upset the system.
Could it be a microstepping/memory problem? Could it be a problem with my first layer settings? (it happens whether i'm using a raft or not). Is it a bug?
I'm printing in Simplify 3D via USB, running Repetier 0.92 on a RAMbo ver1.3 (arduino is on 1.6.9).
Thanks in advance!
Rostock Max V2 w/ e3Dv6 hotend, Bondtech QR Extruder, TrickLaser Carbon Fiber Arms. S3D settings and eeprom attached below:
Thanks in advance!
