what else is connected to fuse3? i was hooking up a new fan and had everything running, but then the leds (hot end on and P6 on) went dark. im on v1.1b, e3d 40w heater and a 12v .9A max fan = 40/12 + .9 = 4.5A is there another place i can run this fan on a different fuse but still controllable with pwm??? where can i order more of these baby fuses?
i blew f3
Re: i blew f3
Bed heat has its own fuse, so just the fan and extruder outputs. Replacing it with a 10A version of the fuse is the usual solution for this problem.
Re: i blew f3
The 10Amp fuse to replace the 5 amp is listed at Mouser.com Part # 576-0448010.MRbubbasnow wrote:what else is connected to fuse3? i was hooking up a new fan and had everything running, but then the leds (hot end on and P6 on) went dark. im on v1.1b, e3d 40w heater and a 12v .9A max fan = 40/12 + .9 = 4.5A is there another place i can run this fan on a different fuse but still controllable with pwm??? where can i order more of these baby fuses?
Re: i blew f3
ok ill buy some of each.. thanks!!
Re: i blew f3
its going to be a long weekend... the parts wont be in till next week
Re: i blew f3
Just sit and think happy thoughts and dream of all the upgrades you would like to do.bubbasnow wrote:its going to be a long weekend... the parts wont be in till next week
Re: i blew f3
i think ill go buy a quickburn 125v/10A, and solder leads onto the bad LF and the new fuse, and slide that puppy back into place until the replacement comes.
Re: i blew f3
That should work, glad you don't have to spend all weekend without your printer.bubbasnow wrote:i think ill go buy a quickburn 125v/10A, and solder leads onto the bad LF and the new fuse, and slide that puppy back into place until the replacement comes.
