Has anyone created a config file for using Repetier's firmware builder on the website? I'd love to play around with V.092 and keep up with the more current revisions.
http://www.repetier.com/firmware/v092/index.html" onclick="window.open(this.href);return false;
I'm currently running "stock" Rambo electronics, and would love to have a starting point to jump off of.
Config file for Repetier firmware builder
- briankb
Re: Config file for Repetier firmware builder
I second this request.
I posted one in my build log. You'll need to scroll down a bit http://forum.seemecnc.com/viewtopic.php ... &start=175" onclick="window.open(this.href);return false;
Let me know if anything needs changed
Known working config file. Just rename to configuration.h
- Configuration-2.h
- (23.98 KiB) Downloaded 348 times
How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
I've got it set via the EEPROM but its far easier to adjust it via the LCD.
Not sure about which exact version I'm running, but on mine it's: click, scroll to advanced settings at the bottom, click, scroll to set z height at the bottom.Jrjones wrote:How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
So go to the bottom of the menu list, two layers deep, and you'll find it there.
Ah, I got it.
I had changed the Z_HOME_DIR to 0 because I thought it was making the carriages move up into the limit switches after homing. But it also turns off the Z Calibration menu if its set to zero.
