Cura slicing returns 0 layers
Posted: Thu Dec 18, 2014 2:53 pm
Hi all,
Noob here. I did a pretty decent test print using Cura with 0.15 mm layers, and wanted to make it a little finer--adjusted layer thickness to 0.1 mm and changed nothing else. For some reason when I slice it, the preview shows up empty: about 4 hours of print time (which sounds about right) but 0 layers. The G-Code only shows the "Generated with Cura" header, and is otherwise blank. Any idea what is going on here?
