Sculptris by Pixologic
Posted: Wed May 01, 2013 9:43 am
I was searching for sculpting software recently and found Sculptris. The software is here: http://pixologic.com/sculptris/
Very intuitive and fun. To print something you create, export the .OBJ file, then open the .OBJ using Slic3r. After scaling and orienting, you can export the .STL. Finally, open the .STL in Repetier and process as usual.
