First look at the new EZR Struder!
I was lucky enough to get my paws on one of the brand new EZR Struders, and I thought you guys would want to have a sneak peek at it, too!
http://www.youtube.com/watch?v=cWQb-NzpYU8
If I missed any angles that you want to get a better look at, just let me know and I'll post some pictures.
Last edited by Jimustanguitar on Wed Aug 03, 2016 6:36 pm, edited 4 times in total.
Re: First look at the new EZR Struder!
Anybody know why I can't embed it correctly? It seems pickier than usual this time.
Last edited by Jimustanguitar on Wed Aug 03, 2016 6:37 pm, edited 2 times in total.
Dammit Jim, you beat me to posting your video. :D
Thanks for taking the time to make it!
What happened to the video? The link no longer works.
jjjohnson
SeeMeCNC Staff
Post by jjjohnson »
Hey guys, here is the assembly guide for the EZR Struder. This will give you and idea of the assembly process and how simple it is. http://seemecnc.dozuki.com/Guide/EZR+Struder/42
JJ
Tincho85
Post by Tincho85 »
This is just pure evil, still no video! :(
Come on Jim, upload it again.
Martín S.
Post by Mac The Knife »
Tincho85 wrote:This is just pure evil, still no video! :(
Try the link,,,, https://youtu.be/cWQb-NzpYU8
It's there now. We had an edit to make, and it took 3 hours to upload and process again.
Tincho85
Post by Tincho85 »
Sweet, thanks! I did try the link but I guess it was just not proper timing hehe
Watching it right now.
Martín S.
Still not sure what's going on with the embedded player. It's working on other boards and on Facebook just fine...
KAS
Post by KAS »
U.S. Water Rockets
Post by U.S. Water Rockets »
That looks promising. I messed around with some semi flexible filament a while ago, and I had to make a custom bit of PTFE tube that went right to the edge of the hobbled gear, because the stock EZStruder was forcing it every which way but down the Bowden.
626Pilot
Post by 626Pilot »
Great!!! But - will it accommodate the same width of drive gear as the old EZStruder? I'm using one from TriDPrinting (12.5mm OD) that goes with their geared stepper's 8mm shaft. You really need a geared stepper for hot ends like the Cyclops. I'd love it if I could swap this in and get that fully supported filament path!
PartDaddy
Post by PartDaddy »
The PTC fitting is by John Guest. It is called a "half cartridge" fitting. John Guest is a great company and has been around for a very long time.
As for the hobbed drive gear, yes, exactly the same. John Oly will post these for sale this week! Look for them on our website.
Thanks to the Maker Hive for just doing a review video, nice !!
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
I'll probably be hooking that bad boy up over the weekend. Any specifics that you want me to take a closer look at?
I brought the new extruder to The Hive last night, and everybody that inspected it closely was pleased with it and eager to hear about how it works.
Glacian22
Post by Glacian22 »
Looks nice! I particularly like the completely constrained filament path and linear spring mechanism!
Me too. We'll see if I can print flexibles like the guys were able to do the other day.
https://www.facebook.com/seemecnc/photo ... 74/?type=3
Qdeathstar
Post by Qdeathstar »
Hi jim,
How much did it cost you?
Qdeathstar wrote:Hi jim,
Maybe not him. but for you.... https://www.seemecnc.com/collections/parts-accessories/products/ezrstruder
PartDaddy
Post by PartDaddy »
~PartDaddy
Since 1996
AlanZ
Post by AlanZ »
I just ordered two of them. One for my Eris, hopefully will make loading much easier, and avoid some feed problems I have been having. If that works out well, the other will go on my Max 2 which has a longer than stock Bowden tube because I mounted the extruder outside of my enclosure. Looks like a nice upgrade, and hope it comes stock on new units.
AlanZ
Post by AlanZ »
Is the stock configuration of the Bowden tube on the Eris long enough to fully seat into the new EZStruder, or do I need a longer tube?
After replacing the tube in mine, I would say yes if you feed the tube through the wire sleeve.
AlanZ
Post by AlanZ »
Mac, I don't quite understand your answer. Does the existing Eris tube need to be rerouted and exit the sleeve in a different place to add some slack?
Qdeathstar
oh... he didn't say he got it for free in the review.... $35 isn't bad..
Return to “The Lounge”
