Print quality is just about perfect -- w00t!!
- michaellatif
I think I have slic3r and Repetier firmware/host tuned in to almost perfect values.
Here is my latest print (kinda geeky ) I will create a post in the Sanguino area for settings/values.
Mike Latif
H-1 #3
H-1 #3
- Chris Muncy
Re: Print quality is just about perfect -- w00t!!
Hmmm very nice! Now time for a Federation emblem!
Chris Muncy
H-1 #5
H-1 #5
Geeky is Cool
- Chris Muncy
Michael,
Time to print this: http://www.thingiverse.com/thing:20674
[img]http://thingiverse-production.s3.amazon ... _large.jpg[/img]
[If you don't know what this is]
Aperture Science
Aperture Science
Chris Muncy
H-1 #5
H-1 #5
It has to be a part of your own mini stargate.
G
G
- Chris Muncy
Like this?
http://www.thingiverse.com/thing:6901
[img]http://thingiverse-production.s3.amazon ... medium.jpg[/img]
Chris Muncy
H-1 #5
H-1 #5
- michaellatif
Challenge accepted!
First picture is when the print was about 60% complete, second is of a quickly cleaned up print.
Not bad for first attempt with my default settings in slic3r.
Mike Latif
H-1 #3
H-1 #3
- Site Admin
Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
I make no addmission on my nerddom:] But that is going to be a very cool stargate for G.I. Joe.
G
G
Good thing the Star Trek communicator badge would not print uhhhhh.... for my wife....seemeadmin wrote:Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
http://www.thingiverse.com/thing:14345
Can anyone print this? I tried Slic3r but get manifold errors and only partial gcode. I tried to fix it in Netfab but no luck.
__
Chris
Chris
- michaellatif
I couldn't get that one to print, I however printed the following one:cquinby wrote:Good thing the Star Trek communicator badge would not print uhhhhh.... for my wife....seemeadmin wrote:Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
http://www.thingiverse.com/thing:1209
Mike Latif
H-1 #3
H-1 #3
Cool... I will try that one after I test a new spacer designed for 608 bearings to 1/4 rod for my spool adapters.
__
Chris
Chris
Try this file: I ran it through netFabb to correct any manifold issues and it now slices perfectly.cquinby wrote:Good thing the Star Trek communicator badge would not print uhhhhh.... for my wife....seemeadmin wrote:Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
Anthony
Anthony Leander
Running the Creeper Creator
- Chris Muncy
I guess I am going to have to download Netfab and keep that handy as I have a few things I want to print that have the same issue.
Chris Muncy
H-1 #5
H-1 #5
They have a nice cloud based service that I used if you don't want to bother with learning a new program.
Simply upload your file and then download the fixed one.
Nice and easy.
Nice and easy.
Anthony Leander
- Chris Muncy
Very cool!ALeander wrote:They have a nice cloud based service that I used if you don't want to bother with learning a new program.
Nice and easy.
http://cloud.netfabb.com/
Chris Muncy
H-1 #5
H-1 #5
- michaellatif
NICE!! I have a few items that I want to print but ran into manifold issues during slicing.Chris Muncy wrote:Very cool!ALeander wrote:They have a nice cloud based service that I used if you don't want to bother with learning a new program.
Nice and easy.
Mike Latif
H-1 #3
H-1 #3
Hey guys, another thing we've noticed with some .stl files not slicing easily, check your drawings units! I keep replicatorG around and handy now, because it's an awesome way to open your stl file and see where it is in relative position, rotate it, scale it, then save it. We've found quite a mix of metric and imperial drawings on the web. If you try and slice a file drawn in inches, slic3r gives errors usually. When you use slic3r and set the scaling to 25.4, it slices!
- Chris Muncy
I've noticed that too. If I have issues I open it up in ReplicatorG, convert Inch to mm, save it, slice it with Slic3r, and I'm good to go.
Chris Muncy
H-1 #5
H-1 #5
