Extruder skipping
Vic
Extruder skipping
Post by Vic »
I have an Orion which is about 5-6 years old. Updates include e3d hotend and ballcup arms and platform. I have it calibrated very well and have been very pleased with the performance.
Recently the extruder started to skip. I updated to the EZR thinking it was a bad hobbed gear. No help. It seems to not have enough torque to push the filament. The hotend heats up well. I can manually extrude by turning the knob. I reflashed the firmware with increased stepper current from 130 to 140. I also disassembled the hotend and it looked good without any obstruction and the nozzle is clear.
I have searched to forum as well as google and can't come up with any other ideas.
Could the stepper motor be bad?
Any help would be greatly appreciated.
Re: Extruder skipping
The motor should be ok - I would check to make sure that the wiring is ok. There might be a nearly-failed crimp at the connector end.
Vic
Post by Vic »
Thanks I'll check it
Return to “ORION”
