Filament orientation
Posted: Thu Nov 19, 2015 10:53 pm
by LAFilament
I thought I remembered seeing somewhere that the filament should be oriented with the feed coming over the top of the spool as the best way to do it if you are routing it as per the instructions
Am I remembering correctly?
Thanks,
Mo
LAFIlament.com
Re: Filament orientation
Posted: Thu Nov 19, 2015 11:48 pm
Whichever way feeds the filament at the straightest angle is the right choice. Other than that, it doesn't really matter. I feed mine over the top.
Posted: Sat Nov 21, 2015 11:55 am
by LAFilament
Thanks. I think the tension on the extruder spring is a bit low.
Posted: Sun Nov 29, 2015 2:55 pm
by LAFilament
forgot to post an update -
The problem that I was having was that it seemed like the printers were starving.
The screw for the tension release was loose. Tightened 'er back up and we're good to go.
