Trying to fix my bench
Posted: Tue Jan 24, 2017 2:40 pm
http://imgur.com/fqGbE9J
http://imgur.com/7n3Cz1N
http://imgur.com/T0hqlpW
Matter control profile
Im using matter control and pla at 210
"DocumentVersion": 201606271,
"ID": "d783eb26-0974-46d6-9ff6-be29a15ea041",
"StagedUserSettings": {
"travel_speed": "150",
"min_fan_speed": "30",
"layer_height": "0.3",
"first_layer_extrusion_width": "180%",
"nozzle_diameter": "0.5",
"external_perimeter_speed": "25",
"build_height": "402.16",
"max_fan_speed": "60",
"perimeter_speed": "25"
"Macros": [
"Name": "Autocalibration",
"GCode": "; Rostock Max v2/v3 Delta Autocalibration Script\nG69 S2 ;Endstop Calibration\nM117 ENDSTOPS CALIBRATED\nG68 ;Horizontal Radius Calibration\nM117 HORIZONTAL RADIUS CALIBRATED\nG30 S2 ;Z height calibration\nM117 Z Height Calibrated\nG4 S2\nM500\nM117 CALIBRATION SAVED",
"ActionGroup": false,
"LastModified": "0001-01-01T00:00:00"
"OemLayer": {
"avoid_crossing_perimeters": "1",
"bed_shape": "circular",
"bed_size": "280,280",
"bed_temperature": "0",
"bottom_clip_amount": "0",
"bridge_acceleration": "0",
"bridge_fan_speed": "100",
"bridge_flow_ratio": "1",
"bridge_speed": "60",
"brim_width": "0",
"build_height": "400",
"cancel_gcode": "M104 S0\\nG28",
"center_part_on_bed": "1",
"complete_objects": "0",
"cool_extruder_lift": "0",
"cooling": "1",
"create_raft": "0",
"default_acceleration": "0",
"disable_fan_first_layers": "2",
"end_gcode": "M104 S0 ; turn off temperature\\nG91\\nG1 Z5.0 E-3.5 F12000\\nG90\\nG28 \\nM84 ; disable motors",
"external_perimeter_speed": "30",
"external_perimeters_first": "0",
"extra_perimeters": "1",
"extruder_clearance_height": "20",
"extruder_clearance_radius": "20",
"extruder_offset": "0x0",
"extrusion_axis": "E",
"extrusion_multiplier": "1",
"extrusion_width": "0.6",
"fan_always_on": "0",
"fan_below_layer_time": "60",
"filament_diameter": "1.75",
"fill_angle": "0",
"fill_density": "30%",
"fill_pattern": "rectilinear",
"first_layer_acceleration": "0",
"first_layer_bed_temperature": "0",
"first_layer_height": "0.3",
"first_layer_speed": "15",
"first_layer_temperature": "200",
"g0": "0",
"gap_fill_speed": "30",
"gcode_arcs": "0",
"gcode_comments": "0",
"gcode_flavor": "reprap",
"gcode_output_type": "REPRAP",
"has_fan": "1",
"has_heated_bed": "1",
"has_sd_card_reader": "1",
"infill_acceleration": "0",
"infill_every_layers": "1",
"infill_extruder": "1",
"infill_extrusion_width": "0.6",
"infill_first": "",
"infill_only_where_needed": "0",
"infill_speed": "40",
"infill_type": "TRIANGLES",
"layer_height": "0.25",
"max_fan_speed": "100",
"min_extrusion_before_retract": "0.5",
"min_fan_speed": "100",
"min_print_speed": "7",
"min_skirt_length": "3",
"notes": "",
"only_retract_when_crossing_perimeters": "1",
"ooze_prevention": "0",
"output_filename_format": "[input_filename_base].gcode",
"overhangs": "1",
"pause_gcode": "G91\\nG1 Z10 E-5.0 F12000\\nG90",
"perimeter_acceleration": "0",
"perimeter_extruder": "1",
"perimeter_extrusion_width": "0.6",
"perimeter_speed": "40",
"perimeters": "3",
"post_process": "",
"print_center": "0,0",
"print_leveling_solution": "3 Point Plane",
"raft_air_gap": ".2",
"raft_extra_distance_around_part": "5",
"raft_layers": "0",
"randomize_start": "",
"repair_outlines_extensive_stitching": "1",
"repair_outlines_keep_open": "1",
"repair_overlaps_reverse_orientation": "0",
"repair_overlaps_union_all_together": "0",
"resolution": "0",
"resume_gcode": "G91\\nG1 Z-10 E5.5 F12000\\nG90",
"retract_before_travel": "5",
"retract_layer_change": "0",
"retract_length": "2.5",
"retract_length_tool_change": "10",
"retract_lift": "0.5",
"retract_restart_extra": "0",
"retract_restart_extra_toolchange": "0",
"retract_speed": "100",
"skirt_distance": "3",
"skirt_height": "1",
"skirts": "2",
"slowdown_below_layer_time": "40",
"small_perimeter_speed": "30",
"solid_fill_pattern": "rectilinear",
"solid_infill_below_area": "20",
"solid_infill_every_layers": "0",
"solid_infill_extrusion_width": "0.6",
"solid_infill_speed": "30",
"spiral_vase": "0",
"standby_temperature_delta": "-5",
"start_gcode": "G28",
"start_perimeters_at_concave_points": "0",
"start_perimeters_at_non_overhang": "1",
"support_material": "0",
"support_material_angle": "0",
"support_material_enforce_layers": "0",
"support_material_extruder": "1",
"support_material_extrusion_width": "100%",
"support_material_infill_angle": "0",
"support_material_interface_extruder": "1",
"support_material_interface_layers": "0",
"support_material_interface_spacing": "0",
"support_material_pattern": "rectilinear",
"support_material_spacing": "2.5",
"support_material_speed": "40",
"support_material_threshold": "40",
"support_material_xy_distance": "1",
"support_material_z_distance": "0.15",
"support_material_z_gap_layers": "1",
"support_type": "GRID",
"temperature": "215",
"thin_walls": "1",
"threads": "4",
"toolchange_gcode": "",
"top_infill_extrusion_width": "0.6",
"top_solid_infill_speed": "40",
"top_solid_layers": "10",
"travel_speed": "200",
"use_firmware_retraction": "0",
"use_relative_e_distances": "0",
"vibration_limit": "0",
"wipe": "1",
"wipe_shield_distance": "0",
"z_can_be_negative": "0",
"z_offset": "0",
"make": "SeeMeCNC",
"model": "Rostock MAX v3",
"created_date": "2016-11-16T20:44:00.626Z",
"baud_rate": "250000",
"default_material_presets": "PLA",
"manual_movement_speeds": "x,3000,y,3000,z,3000,e0,150",
"windows_driver": "MHSerial.inf",
"calibration_files": "Calibration - Box.stl",
"oem_profile_token": "ag9zfm1hdHRlcmNvbnRyb2xyQwsSCUFmZmlsaWF0ZRiAgIDAkMGACAwLEgZEZXZpY2UYgICAgIDXjAoMCxINRGV2aWNlUHJvZmlsZRiAgICA4LCFCgw",
"active_theme_name": "Light Blue - Dark",
"active_quality_key": "",
"infill_overlap_perimeter": "0.25",
"raft_print_speed": "40",
"support_air_gap": "1",
"z_homes_to_max": "1",
"recover_is_enabled": "1",
"bottom_solid_layers": "6",
"heat_extruder_before_homing": "1",
"has_hardware_leveling": "1",
"include_firmware_updater": "Simple Arduino",
"show_reset_connection": "1",
"layer_gcode": "",
"support_material_create_internal_support": "0",
"support_material_create_perimeter": "0",
"auto_connect": "0"
"ActiveQualityKey": "b0c7f8c4-0564-457c-8651-6d29002a1a62",
"MaterialSettingsKeys": [
"dccaa008-b282-4925-ab87-4d737e8b3ae2"
"UserLayer": {
"printer_name": "SeeMeCNC Rostock MAX v3",
"active_theme_name": "Blue - Dark",
"active_quality_key": "b0c7f8c4-0564-457c-8651-6d29002a1a62",
"slicing_engine": "MatterSlice",
"bridge_fan_speed": "0",
"disable_fan_first_layers": "0",
"support_material_spacing": "4",
"retract_restart_extra": "3.5",
"start_gcode": "\\nG28",
"retract_length": "3.5",
"retract_speed": "35"
"MaterialLayers": [
"layer_name": "ABS",
"filament_density": "1.04",
"layer_id": "a9b939f5-c8cb-46a4-8f0d-d34674ebe8c7",
"bed_temperature": "80",
"max_fan_speed": "0",
"min_fan_speed": "0",
"slowdown_below_layer_time": "15",
"temperature": "235",
"filament_cost": "29"
"layer_name": "Ninja-Flex",
"layer_id": "e7dd863c-cf16-465d-ab26-ee70464b86d9",
"bed_temperature": "60",
"bridge_speed": "15",
"external_perimeter_speed": "12",
"filament_density": "1.2",
"first_layer_speed": "12",
"infill_speed": "12",
"min_fan_speed": "60",
"perimeter_speed": "12",
"slowdown_below_layer_time": "30",
"support_material_speed": "12",
"filament_cost": "110",
"retract_length": "0"
"layer_name": "PLA",
"layer_id": "dccaa008-b282-4925-ab87-4d737e8b3ae2",
"bed_temperature": "55",
"temperature": "210",
"layer_name": "PET",
"filament_density": "1.27",
"layer_id": "56f2d892-8d97-4692-84a8-9abbaacc4f40",
"bed_temperature": "75",
"slowdown_below_layer_time": "25",
"temperature": "255",
"filament_cost": "48",
"layer_etag": "",
"layer_source": ""
"QualityLayers": [
"layer_name": "Coarse",
"layer_id": "518066ee-903d-4dab-86ce-72f4cd064658",
"layer_name": "Fine",
"layer_id": "a9382dda-2bac-4285-819d-ffde04e99b41",
"layer_height": "0.1"
"layer_name": "Standard",
"layer_id": "907eb16e-3c76-424e-ac13-6da69e8a8e4d",
"layer_height": "0.2"
"layer_name": "Quality3 (1)",
"layer_id": "e0090010-32b1-4cce-b69e-4dc63d4ee133",
"layer_etag": "",
"layer_source": ""
"layer_name": "Rostock MAX V3 Fast",
"bottom_solid_layers": "0.6mm",
"cancel_gcode": "M104 S0\\nM140 S0\\nG28\\nM4",
"raft_print_speed": "100%",
"end_gcode": "M104 S0 ; turn off temperature\\nM140 S0\\nG91\\nG1 Z10 E-5.0 F12000\\nG90\\nG28 \\nM84 ; disable motors",
"external_perimeter_speed": "50",
"heat_extruder_before_homing": "0",
"extrusion_multiplier": "1.0",
"first_layer_bed_temperature": "90",
"first_layer_extrusion_width": "100%",
"first_layer_height": "0.2",
"first_layer_speed": "20",
"first_layer_temperature": "230",
"has_hardware_leveling": "0",
"include_firmware_updater": "None",
"show_reset_connection": "0",
"infill_overlap_perimeter": "0.5",
"infill_speed": "50",
"infill_type": "LINES",
"print_leveling_solution": "7 Point Disk",
"layer_height": "0.2",
"min_extrusion_before_retract": "1",
"min_print_speed": "5",
"min_skirt_length": "2",
"pause_gcode": "G91\\nG1 Z10 E-10 F12000\\nG90",
"perimeter_speed": "50",
"perimeters": "2",
"resume_gcode": "G91\\nG1 Z-10 E10.8 F12000\\nG90",
"retract_before_travel": "1",
"retract_length": "1",
"retract_length_tool_change": "1",
"retract_lift": "3",
"retract_speed": "25",
"skirt_distance": "6",
"skirts": "1",
"start_gcode": "M104 S195\\nM190 S55\\nM109 S195\\nG28",
"support_air_gap": ".3",
"support_material_infill_angle": "45",
"support_material_create_internal_support": "1",
"support_material_create_perimeter": "1",
"support_material_extrusion_width": "0.5",
"support_material_interface_layers": "1mm",
"support_material_speed": "50",
"support_material_threshold": "0",
"support_material_xy_distance": "0.7",
"support_type": "LINES",
"temperature": "195",
"top_solid_infill_speed": "50",
"top_solid_layers": "0.6mm",
"travel_speed": "250",
"wipe": "0",
"layer_id": "b4a8fe90-38f5-4f9f-a97f-3e043699e162",
"nozzle_diameter": "0.4"
"layer_name": "Rostock MAX V3 no retraction",
"build_height": "350",
"perimeters": "2",
"skirts": "1",
"wipe": "0",
"layer_id": "5b14bc90-a219-496d-a69e-8ac1f1bdfa3b",
"layer_etag": "",
"layer_source": "",
"layer_name": "Rostock MAX V3 vase",
"spiral_vase": "1",
"perimeters": "2",
"skirts": "1",
"wipe": "0",
"layer_id": "7a9d4964-f953-4e08-b7a0-fa85a8e1f841",
"layer_etag": "",
"layer_source": "",
"layer_name": "Rostock MAX V3 slow .1 layer",
"layer_height": "0.1",
"perimeters": "2",
"skirts": "1",
"wipe": "0",
"layer_id": "5162cb33-ba9d-4182-992f-a86154d1ec51",
"layer_etag": "",
"layer_source": "",
"layer_name": "Rostock MAX V3 slow ",
"min_extrusion_before_retract": "2.5",
"min_fan_speed": "20",
"perimeters": "2",
"retract_before_travel": "2.5",
"retract_length_tool_change": "2.5",
"skirts": "1",
"wipe": "0",
"layer_id": "b0c7f8c4-0564-457c-8651-6d29002a1a62",
"layer_etag": "",
"layer_source": "",
"nozzle_diameter": "0.4",
"max_fan_speed": "20"
