Issues with artifacts and over extrusion
Posted: Sun Mar 11, 2018 10:59 pm
Hello all-
I'm finally resurrecting my pre-wifi Duet Rostock Max V2 and I'm having some issues getting the kinks worked out. I'm seeing artifacts in the walls of my prints, and what looks like over extrusion. Please see the attached image.
My printer is set up this way:
Tricklaser CF non-ball end arms (The original tricklaser arms)
Trick Trucks (Original)
Tricklaser effector plate (Original)
E3d v6 hot end
PIE print surface
Duet 0.8.5 with 1.21RC4
FSR bed leveling (seems to work very well!)
ABS black filament, pretty sure I got it from SeeMeCNC but it's a couple of years old.
I'm slicing with Kisslicer 1.6.2, extrusion is 210 degrees. I've measured my ABS filament diameter and set it properly in the materials section of kisslicer. I also calibrated the extruder.
I've tried reducing the "flow tweak" in kisslicer but it's had no effect.
[img]https://i.imgur.com/4vylyC6.jpg[/img]
Any thoughts as to where to start looking?
Thanks-
Mark.
E3d v6 hot end
PIE print surface
Thanks-
Mark.
