G-code for LCD Encoder?
Post your prints with the GCode used to help other users achieve a similar result, or get help.
jmargush
Post by jmargush »
I recently started this project to make my own custom pause G-code and I wanted to add a function to resume the print with the click of the encode on the LCD Panel. I looked on the Wiki page for possible commands that are compatible with the Repetier Firmware but I never found anything to use the encoder. Now I am wondering if it is possible to control the printer with the encoder to start the printer the way I want to. Suggestions or ideas would be greatly appreciated. Thanks for your time.
Re: G-code for LCD Encoder?
Hi jmargush!
See this link, it may be of some help to you.
http://forum.seemecnc.com/viewtopic.php?f=77&t=5916" onclick="window.open(this.href);return false;
Return to “GCode & Test Prints”
