Changing the Beeping Sounds
Post your prints with the GCode used to help other users achieve a similar result, or get help.
tamcofarms
Post by tamcofarms »
I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2. Any clue or documentation as to how I could do something similar. Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
emile1138
Re: Changing the Beeping Sounds
Post by emile1138 »
I am also now interested in such things.
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
bot
Post by bot »
I would have figured you were the one with the R2 sounds to begin with!
*not actually a robot
emile1138
Post by emile1138 »
bot wrote:I would have figured you were the one with the R2 sounds to begin with!
I take this as a compliment, and a fantastic one at that! Thank you! Lol
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
DarrenAnton
Post by DarrenAnton »
tamcofarms wrote:I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2. Any clue or documentation as to how I could do something similar. Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
Here...
https://www.youtube.com/watch?v=ITXavSI ... ploademail" onclick="window.open(this.href);return false;
http://ddrboxman.github.io/RepRapRingtone/" onclick="window.open(this.href);return false;
http://arcadetones.emuunlim.com/arcade.htm" onclick="window.open(this.href);return false;
IMBoring25
Post by IMBoring25 »
Every time I tried to change the frequency of the stock Rostock beep/buzz, the pitch didn't actually change. I got it to do a few different variations of things that sounded like flutter-tonguing a brasswind instrument, but it was always at its core the same pitch.
Return to “GCode & Test Prints”
