Cellular lamp test print, need help tweaking settings
Post your prints with the GCode used to help other users achieve a similar result, or get help.
RansomDE
Post by RansomDE »
I'm very new to 3D printing. I just got my rostock v2 max fullly built last week. My first prints were fantastic, albeit simple. For example I printed this volleyball and was very pleased with the results:
http://i.imgur.com/eqNf9pT.jpg" onclick="window.open(this.href);return false;
I just printed this cellular lamp http://www.thingiverse.com/thing:19104
Fully aware that it would probably fail catastrophically due to the huge number of moves and retractions, as well as the very thin geometry and steep overhangs. Here is how it turned out:
http://i.imgur.com/AehGvJ6.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/TRt1blz.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/SWEcpyd.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/Kogp4kO.jpg" onclick="window.open(this.href);return false;
So there are 2 main problems:
1. The steep overhangs are printed poorly, there are a lot of drooping layers.
2. There are strands that form on upward diagonal angles (and I have no idea why).
This print was with HatchBox gray 1.75 mm PLA. The layer thickness was set to .2 mm. The hot end was running at 210*C. The infil was set to %10.
What can I do to improve this print? I really have no idea what would cause the odd upwards strands to form. My best guess is something with the retraction settings are wrong. If you guys need any more information, just ask. Any advice is greatly appreciated.
Glacian22
Re: Cellular lamp test print, need help tweaking settings
Post by Glacian22 »
First off, do you have a fan pointed down at the print? If not, that's step one for getting nice prints with PLA. I'd also try running a little cooler, maybe 200c, and increasing the retraction.
RansomDE
Post by RansomDE »
Alright will d o. I do have a fan pointed at the print. I will try running it a bit cooler and see how it affects the print.
I printed a calibration box just after this, a simple hollowed cube with one layer thick walls. I noticed after doing a "move" the hot end wobbled a bit because it moved so quickly, so I reduced the move speed significantly to reduce any wobble in the hot end, which will hopefully help a bit.
Return to “GCode & Test Prints”
