Updating the configuration.h file
Posted: Mon Jan 21, 2013 5:49 pm
We are working off of the Assembly Manual pdf, page 85. Currently, we are trying to work on homing the Z position of the extruder. It seems that no matter what we do, after entering the G28 command and lowering the head to Z 0,00, the extruder always ends up at about 20mm off of the bed. We have tried: turning the screws out (they are about as far out as we are comfortable turning them); changing the Z_Home_POS value in configuration.h; and changing the build height in Repetier-Host to a higher value. While pulling the screws out seemed to work a bit, the software and code changes don't seem to effect the position.
A few questions we have:
Has anyone worked on this specific problem that could help?
We think that possibly the issue is that when we update the confuiguration.h code, we are not correctly updating the link to that file in Repetier. How do you tell Repetier to update with the changes made in the configuration.h file?
Thanks for any help that you can give us!
LV
LV
