Hi, thanks for answering, and that is in fact the issue, although as pointed out in the topic it doesn't create any issues, I tried with and without pauses and I got the same movements.
Which is almost a shame was hoping this would be the problem that I'm having, since I have been trying to use this software
http://forum.seemecnc.com/viewtopic.php?f=36&t=8698 and was able to calibrate with it, however something is probably wrong with my printer, if I go to the same spot but use different means of getting there, for example going directly there vs going to some other spot and only then going there, I end up being at significantly different heights from the heatbed, with differences as high as 0.09mm, this is the code I use to test this (requires a probe to test ofc):
G28
G1 Z10 X0 Y0 F5000
G1 Z10 X-110 Y-65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X110 Y65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X110 Y-65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X-110 Y65 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X0 Y130 F5000
G30
G1 Z10 X0 Y0 F5000
G1 Z10 X0 Y-130 F5000
G30
G28
G30
G28
G30
G28
G30
G28
G30
G28
G30
G28
G30
At this point I have spent over 20 hours testing things, have disassembled and reassembled the cheapskates 3 or 4 times (and adjusted them every time), have completely removed the belts to check for damage, have disassembled the arms and reassembled them, have even put some rubber bands on them to see if it solved the issue, have adjusted the belt tension several times, have checked tower alignment also several times and they are all at 90º (give or take 0.1º). So far the only thing I can spot that is probably not correct with the printer, is that I get black crumbs from the belts even at the top, which probably means that the belt is rubbing on the tower, but no idea if that's normal or not, and also no idea on how to fix it if it isn't.
