Had a few issues so far that slowed me down quite a bit.
1. The manual has so much to read through and much filtering through revisions. I believe It would be best if the manual was split into each revision. - also the current manual does not provide a revision for Rev7 that I bought.
My electrical cables and even base design is different than the photos and it took a bit of time to realize that my printer was a new revision.
2. Not being too familiar with identifying wire sizes selecting to cut (not for a long time) one of the two pictures that show conductor cables were the same color, but without thinking things through further I referenced the pictures by size and color. *Notes in the manual like: 18ga wire is the largest in diameter, followed by the 22ga wire and the 26ga wire is the thinnest." -should be added in the manual **at the beginning before cutting** not closer to the end .. and also remind people to look at the wire itself to reference the correct gauge when ever relevant if the gauge is written on the wire.
3. There is a list/statement on the front page of Rostock Max V2 of tools and additional supplies that is apparently required to complete a build but the manual references more things like kapton tape, Blue Threadlock etc. I actually got confused in the beginning thinking that the listing of Permatex twice in the document was referencing an older product for the Hotend not realizing that the threadlocking supply was for the motors and the ultra copper gasket maker was for the hotend because the webpage only listed "High Temp RTV silicone for retaining heating resistors/thermistor in hot-end, or High Temp expoxy".
My Rev7 came with two leds and two resistors.. but my hotbed only allows for 1 led and 1 resistor.. there is no instructions for these "extras"? are they now extras?
4. Both adhesive prep for the hotend and the hotbed should be together at the beginning. Also a quick note where these supplies like "Permatex" could be found like the automotive area of a hardware store would be very helpful.. took a bit of time searching online trying to find what stores might carry it.
5. On the product page it states to either crimp or solder to be able to complete the build but soldering is essential for the hotbed.. can't crimp anything there.
6. If I may suggest to keep information condensed on page 88 I would write this if correct:
Inside the center of the Aluminium extrusion designated for the for the z axis feed the18ga hot end wires
Inside the center of the Aluminium extrusion designated for the x axis feed the end-stop wires into the center
Inside the center of the Aluminium extrusion designated for the y axis tower feed the 22ga wires for the extruder as well as two pair of 26ga wires for the
PEEK fan and the layer fan
(Following the current instruction in that area lead me to believe there would be a 4th Aluminium extrusion although there isn't one.) Also please keep either one* name reference like "Aluminium extrusions" or "Aluminium Towers/Posts" - not multiple. - keep it short and simple.
7. When mounting the Aluminium extrusions it would be good to mention an ideal length of the cable coming out of the bottom because we don't know in advance where the Rambo card will be placed and if there will be other obstacles in the way that may require us to have more cable length.
8. Page 121 - please don't write in the manual what you messed up on the past (every future written documentation should be about the new improved design and method of installation - a focus on quick and easy rather than bloating it with the past otherwise it just makes it harder to follow) You could make a change history log at the end of the manual if you feel that might help veterans and first timers.
9. Big error: please correct me if I'm wrong but I've followed the obscure steps of assembling the extruder wires, page 149 it's written to only use the hotend wires that are fed through the Aluminium extrusion "Z" and in the wiring instructions for the Aluminium extrusions z is only for the hotend wires (page 88) and y contains both the 22ga and 26ga wires. Page 153 (hotend wiring completed) shows the red wires have been assembled in the mesh loom although this wasn't directed to feed them into the mesh loom along with the hotend wires.. so I ended up shrink wrapping BEFORE realizing this issue.. I was thinking maybe the 26ga wires had it's own sleave/mesh loom covering.
10. Although on page 150 it's part of the hotend assembly, there is no parts listing for "barrel crimps" in the manual.. so what's the alternative soldering??
11. My Rambo fan produced an oscillating noise and I found the only thing that was able to stop it was to have a "slight" obstruction screwed onto the fan about thumb tip size or guitar pick. I Adjusted it with the power on to hear the fan's sound change. This altered the sound to be steady.
12. I am not impressed by the fact that two fans were sent to me but not the adaptors to mount them! I understand that in the manual your instructing us to print the fans but if this were a complete kit I would suggest to either include the fans or a generous supply of the material to print them!
13. Getting into the part about inserting the 2 meter filament, I realize the filament feed hole has been changed to a new area Page144 (the hole is now one the other side so the stepper motor now has to be changed and added to the back)
14. My hotend melted the PEEK HOT END INSULATOR .. so disappointed.. the thermistor is in place, extruder temp set to 140 for using Taulman's Bridge Filament. On the SeemeCNC product Webpage it states I can print using Taulman Nylon which his Nylons are stated to have the printing temperatures of approximately ]240-245 C
http://www.taulman3d.com/nylon-618-spec.html I Kept my Extruder at 240 and as I fed the filament in, it pushed out the PEEK HOT END INSULATOR along with melted filament! What now??
I will update this list if I can to show my experience so far and give others a heads up. I hope the manual can be updated soon.
