Rostock Max V2 Upgrades
Posted: Mon Feb 21, 2022 10:45 pm
Hello everybody. I'm new to the forum and 3D printing in general. It's a hobby that I've always been interested in, as I really like electronics and creating things. I made my way to the forum, because I recently ended up with a Rostock Max V2 that needed work in a bad way. It's a bit of a long story, but I'll try to explain so people get the full picture. Basically, what I want to ask about here is some assistance with picking new parts and solving my existing problems. I realize that some of the things that I'm going to list on my purchase list are probably overkill, but I want a working machine that can print consistently well.
I got the machine a couple months ago. I had some friends that were in a club. Their club was given a space to have their meetings and work on club activities. That space used to belong to another club, which turned out to be the 3D printing club. When they were given the space, they were told that anything that was in there became theirs. Among the items found, one was this Rostock Max V2. They had no use for it, and were going to throw it away, so I saved it with the hopes of getting it working again.
It appears that the machine sat locked away in a basement for a few years. It had about 4 to 5 days of print time listed on it only, but the thermistor on the hotend had been removed, and none of the cooling fans on it worked. I didn't know what shape the hotend was in, so I bought a new stock one from SeeMeCNC and two new fans. I replaced the stock power supply with an 850W modular one as well. I made sure everything was wired correctly, installed the new parts, calibrated the machine according to the manual I found online, and made sure that I could extrude filament. Everything seemed to be going OK, so I tried some prints, but this is where I start to have problems.
My first print, I realized that somewhere in it's lifespan the spool arm got broken. I printed one, that came out meh, but solid enough to work, although I had to stand there and manually feed it for an hour or so. At this point I started trying to get my settings correct and get good quality prints, but I could never escape having some kind of issue. I have only tried printing in PLA and silk PLA so far. In no particular order, and continually coming back I would have:
So, that is the current state of the machine now. At this point, I'm incredibly frustrated, because I basically have a huge paperweight. Where I want to go from here is to do a complete overhaul and upgrade most every part. I realize that it might be cheaper to simply scrap the machine and buy another brand new one, but I have sunk a lot of time into this one and am willing to spend some money upgrading the thing, if it will make it work. I have a parts list put together and I also wanted to ask if these parts will work with the machine and hopefully make things better:
- misaligned layers- tried making sure towers were super tightened down
- warping- tried using painters tape, turning up bed temps, keeping room printer is in warm and staying away from temp variations
- deformed prints- tried turning temps down, calibrating better and more often
- droopy overhangs- same as above
- MANY bed adhesion issues- tried painters tape, turning bed heat up
- filament clogging in nozzle- tried turning temps up, turning down extrusion speed
- filament jamming and breaking in cold end CONSTANTLY- tried repositioning under spool better to create a gentler angle of travel
- cold end motor gets hot enough I can't touch it and starts to smell a bit burny- started pointing a desk fan at it during prints
- A few times it has just stopped printing and froze midprint- restarted it and it didn't happen again
- One time it homed itself and starting extruding filament as fast as it could until I manually killed power- I have no idea, it only did it once
- Duet 2
- PT 1000 Thermistor
- Phaetus Dragon
- 70W 500C Heaters
- blTouch Automatic bed leveling sensor
- Maybe new carriages? Not sure on if there is a better replacement or if it would matter
- Maybe new arms, again not sure if there is a replacement that is better or if they're needed
- Probably a new cold end, or new motor, unsure on this one as well
