Can the RMAX V2 do a nozzle prime/wipe at start of print?
Posted: Thu May 21, 2015 12:45 pm
by EL Cuajinais
Mine has never done the prime/wipe thing at the beginning of a print as I have seen many Cartesian printers do in YouTube videos. Is this something the RMAX simply does not do? I’m using S3D as my slicer.
Re: Can the RMAX V2 do a nozzle prime/wipe at start of print
Posted: Thu May 21, 2015 1:01 pm
by jjjohnson
This is something that does not really have to be machine specific. You can indeed have custom starting GCODE that would "prime" the hot end, and if you wanted there could be a designated wiping area. Most commonly this priming is automatically accomplished by creating a SKIRT around the object (done in slicing settings). Not too familiar with S3D, but I would imaging that its an option.
Posted: Thu May 21, 2015 1:12 pm
by bot
A skirt is good (in S3D, located in the "additions" tab of the process settings screen -- with the advanced settings option enabled) and if you want to add a prime wipe BEFORE the skirt, to get a perfect skirt, you can do that in the "scripts" tab.
If you want to prime and wipe before the prime and wipe, just keep going... adding g code until you have enough wipe and primes.
Posted: Wed May 27, 2015 11:40 am
by RAMTechRob
I did a few things to eliminate the wipe needed. Heat the bed before you heat the nozzle. Add a twice around skirt. That seems to give me great first layers.
