Never printed before. I would like to know if there are specifications for filament I can quote to ensure I get good filament or is it simply a matter or buying from a trusted supplier?
Also, can anyone recommend an ABS filament supplier in Paris, France?
What are the filament specifications?
Re: What are the filament specifications?
If you're in Europe, check out Colorfabb.
The specs and chemistry vary considerably between manufacturers, and most if it is undocumented/unconfirmed so your best bet is to find a supplier that you trust.
Thanks. I am in Africa but Europe is probably my nearest best bet for colorFabb filament. I will give them a try.
Hank
Hank
You want the 1.75mm stuff.
ABS or PLA is up to you.
