Help with DropLit build
Posted: Sat Dec 13, 2014 11:08 pm
by gibeaug
Took advantage of Black Friday discount and purchased a DropLit kit (and a 2nd Max V2
Using Gene's build manual - version 0.50, September 29th, 2014.
On Page 23 (Part 4 - Building the DropLit Chasis) - Fig 4.1 shows the Arduino mounting holes. The images shows a cluster of 9 holes in the area where the Arduino mounts - my base only has 5 (4 small and 1 large) - but none of the holes that the image shows with green circles around them.
Am I missing something - or do I need to drill my own holes?
Thanks in advance,
-George-
Re: Help with DropLit build
Posted: Sun Dec 14, 2014 1:40 am
I don't know the answer to your exact question, but I'd print an adapter plate on your 1st V2 before I'd drill a hole in new wood
DropLit manual observations
Posted: Sun Dec 14, 2014 12:14 pm
by gibeaug
I will post manual comments as I go through the build.
Fig 3-6 shows the left side (with hinge holes) but figure 3-7 shows the partial assembly with the right side connected - if you follow the directions from 3-7 on - you will end up with the hinge side on the right - as I did
Re: DropLit manual observations
Posted: Wed Dec 17, 2014 9:25 am
by buchseb
gibeaug wrote:I will post manual comments as I go through the build.
Hi! I had the same problem, it's fine if you install it in the mounting holes just below the original holes.
Posted: Wed Dec 17, 2014 10:03 am
by gibeaug
Received this from tech-support;
George,
The picture in the manual needs an update. The Uno is actually set back about almost to the middle of the plate that it mounts onto. You will be able to move the uno around and find the hole pattern that matches on the melamine.
If you do want it closer to the edge, you can certainly drill your own holes.
As per the dish base, when standing in front of the machine looking at it, the hole should be on the right side of the machine. (See attached image)
Posted: Fri Dec 26, 2014 1:01 am
by artexmg
gibeaug wrote:Received this from tech-support;
George,
I am about to embark in the same quest, so, I would much appreciate if you post the picture that seems to be missing
Posted: Fri Dec 26, 2014 9:58 am
by gibeaug
Here are a couple of pics I received from Tech Support.
Also - the manual references putting 3 cheapskates and 6 R4 bearing bushings - - what you will have in the build kit is 2 solid strips of 4 R4 bearing bushings - these do not come apart - you will have 4 cheapskate bearings on the front side of the carriage plate - and everything lines up perfectly.
- Dish base orientation - Large hole on right.
- New location for Arduino Uno.
Posted: Wed Jan 07, 2015 3:38 pm
by artexmg
gibeaug wrote:Here are a couple of pics I received from Tech Support.
Thanks for the pictures, that helps!
