OFFSETS OFF BY TOO MUCH _ TRYING AGAIN
The ERIS Delta, a truly affordable entry into Delta 3D Printing
626Pilot
Post by 626Pilot »
This printer seems to go out of calibration about once every 20 or so printing hours. When I try to recalibrate it, I get this, over and over, with no resolution after five minutes of doing exactly the same step:
17:32:15.625 : X: 0
17:32:15.626 : Y: 268
17:32:15.626 : Z: 419
17:32:16.458 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
17:32:16.462 : Info:Autoleveling disabled
17:32:19.652 : X:0.00 Y:0.00 Z:173.050 E:9.1775
17:32:19.652 : Info:Autoleveling enabled
17:32:19.656 : Info:Autoleveling disabled
17:32:22.934 : read reg 49 value: 101
17:32:22.934 : read reg 53 value: 0
17:32:22.934 : read reg 57 value: 0
17:32:22.934 : read reg 45 value: 8
17:32:22.938 : read reg 49 value: 21
17:32:22.938 : read reg 53 value: 0
17:32:22.938 : read reg 57 value: 0
17:32:22.938 : read reg 45 value: 8
17:32:22.939 : Z-probe state:L
17:32:22.939 : zprobing...
17:32:23.188 : Z-probe state:H
17:32:23.188 : Z-probe:19.87 Step Variation from Probe to bed Distance:-10.00 X:-54.00 Y:-31.00
17:32:23.454 : read reg 49 value: 101
17:32:23.458 : read reg 53 value: 0
17:32:23.458 : read reg 57 value: 0
17:32:23.458 : read reg 45 value: 3
17:32:23.458 : read reg 49 value: 21
17:32:23.462 : read reg 57 value: 0
17:32:23.463 : read reg 45 value: 5
17:32:23.463 : Z-probe state:L
17:32:23.463 : zprobing...
17:32:23.713 : Z-probe state:H
17:32:23.715 : Z-probe:19.87 Step Variation from Probe to bed Distance:-10.00 X:-54.00 Y:-31.00
17:32:26.211 : read reg 49 value: 101
17:32:26.211 : read reg 53 value: 0
17:32:26.211 : read reg 57 value: 0
17:32:26.216 : read reg 45 value: 5
17:32:26.216 : read reg 49 value: 21
17:32:26.216 : read reg 53 value: 0
17:32:26.216 : read reg 57 value: 0
17:32:26.216 : read reg 45 value: 4
17:32:26.216 : Z-probe state:L
17:32:26.218 : zprobing...
17:32:26.503 : Z-probe state:H
17:32:26.505 : Z-probe:23.26 Step Variation from Probe to bed Distance:261.00 X:54.00 Y:-31.00
17:32:26.809 : read reg 49 value: 101
17:32:26.809 : read reg 53 value: 0
17:32:26.809 : read reg 57 value: 0
17:32:26.809 : read reg 45 value: 3
17:32:26.813 : read reg 49 value: 21
17:32:26.813 : read reg 53 value: 0
17:32:26.813 : read reg 57 value: 0
17:32:26.813 : read reg 45 value: 7
17:32:26.813 : Z-probe state:L
17:32:26.813 : zprobing...
17:32:27.101 : Z-probe state:H
17:32:27.103 : Z-probe:23.27 Step Variation from Probe to bed Distance:262.00 X:54.00 Y:-31.00
17:32:29.673 : read reg 49 value: 101
17:32:29.673 : read reg 53 value: 0
17:32:29.673 : read reg 57 value: 0
17:32:29.673 : read reg 45 value: 6
17:32:29.673 : read reg 49 value: 21
17:32:29.677 : read reg 57 value: 0
17:32:29.677 : read reg 45 value: 5
17:32:29.677 : Z-probe state:L
17:32:29.677 : zprobing...
17:32:29.988 : Z-probe state:H
17:32:29.988 : Z-probe:25.14 Step Variation from Probe to bed Distance:411.00 X:0.00 Y:65.00
17:32:30.316 : read reg 49 value: 101
17:32:30.316 : read reg 53 value: 0
17:32:30.316 : read reg 57 value: 0
17:32:30.316 : read reg 45 value: 0
17:32:30.316 : read reg 49 value: 21
17:32:30.320 : read reg 53 value: 0
17:32:30.320 : read reg 57 value: 0
17:32:30.320 : read reg 45 value: 5
17:32:30.320 : Z-probe state:L
17:32:30.320 : zprobing...
17:32:30.631 : Z-probe state:H
17:32:30.631 : Z-probe:25.15 Step Variation from Probe to bed Distance:412.00 X:0.00 Y:65.00
17:32:30.958 : Info:Reset Z height
17:32:30.958 : Printer height:173.05
17:32:30.963 : Info:Autoleveling enabled
17:32:30.988 : OFFSETS OFF BY TOO MUCH _ TRYING AGAIN: 21
17:32:30.988 : X: 0
17:32:30.988 : Y: 271
17:32:30.988 : Z: 421
Clearing the EEPROM doesn't fix this, nor does flipping the plate over and letting it tap the glass directly. What should I do? They sell this printer with auto-calibration, and I need it to work as advertised.
Re: OFFSETS OFF BY TOO MUCH _ TRYING AGAIN
Have you contacted support about it?
626Pilot
Post by 626Pilot »
Sent them an email with a link to this thread. Let's see what they say.
Post by Mac The Knife »
So, did they ever come up with a solution?
I finally installed dev firmware, version 20161123, with better calibration results.
626Pilot
Post by 626Pilot »
A few business days after I sent the email, they wrote back that it sounded like loose stepper pulleys. None were actually loose, although there was one grub screw that could stand some tightening down, so I did that. (There are two per pulley, and its neighbor wasn't loose at all.) It did calibrate after I did that, but it still has this issue where the nozzle is too high near the Z tower and too low on the opposite side of the bed. I told them that, sent a photo of the first layer results, and haven't heard back yet.
Repetier does have planar correction (3-point test, like shimming) and regular grid-based depth-mapping. Maybe one of those features should be used in the calibration commands.
626Pilot
Post by 626Pilot »
They wrote back that there's some newer firmware that handles edge cases like mine. They think they'll release on Friday.
precision
Post by precision »
Our Eris also started doing this. Upon inspection it appears that one of the black endstop triggers on the Z tower belt had somehow shifted 5-6 mm. By moving that back to be more in line with the X and Y towers I was able to get the firmware to successfully autocalibrate and print.
626Pilot, have you tried the new OctoPrint plugin or the calibration page on your Eris yet?
626Pilot
Post by 626Pilot »
Not yet. I've got so much stuff to do!
Return to “ERIS Delta”
