HE280 with Duet and PT100?
DerStig
Post by DerStig »
The Duet allows you to use a PT 100 rather easily with it's daughter board. Right now I'm looking at putting the accelerometer board from a HE280 on a E3dV6 and using a PT100....
Until I remembered that the HE280 uses one of the thermistor terminals as a ground.
So.... How do i make this work?
Re: HE280 with Duet and PT100?
Add an extra wire or two. There is no reason to only use the 8 pin HE280 connector. And move ground to a different connector or even the ground terminal itself.
Return to “Mods and Upgrades”
