My setup:
- Rostock Max V2
- Stock hotend
- Duet 0.85
- Ultibots FSR kit w/ mhackney's FSR mounts
- Ball joint arms and molded carriages
- PEI bed
- RepRapFirmware for Duet v 1.16
- Web Interface 1.13
If I issue G1 X0 Y0 Z0.2, the center passes the paper test, but if I issue G1 X0 Y100 Z0.2, the nozzle is too high, G1 X0 Y-100 Z0.2 the nozzle is too low. Also, it seems the more I move between those two points, the worse it seems to get (though I can't tell for sure).
First, tightened all the belts - the issue was still there.
Then I realized I heard creaking in the joints so I thought it might be an arm issue - lubricated the arms and the creaking went away - the issue was still there.
Then I came across the "Unsolved mystery. Weird Z0 behavior" post and it seems like the fix there was a change in Repetier Firmware (Carriage Horizontal Offset). But I am not running Repetier.
I haven't yet tried replacing any of the hardware since I don't really know where to start.
My questions:
- Is this still an issue for other folks, particularly anyone running Duet w/ FSR's?
- Is there an equivalent parameter in the Duet RepRapFirmware that is perhaps in need of adjustment? If so, any idea what that would be?
Any help anyone can provide would be appreciated. Like I said, the printer worked well for ~9 months or so, and I have really enjoyed it until this problem crept up and now it's pretty much unusable since the first layer is so variable.
